Question about Texas Instruments TI-80 Calculator
It is possible to solve problems with matrix using TI-80?
  • Texas Instru... Master
  • 8,073 Answers
I do not have the calculator, so I checked the whole manual. There is no reference to matrices. So you cannot use use this calculator to solve matrix problems.
Sorry.
That should not prevent you from rating the solution.
Posted on Nov 30, 2009
How to solve Matrix Problems on a TI 84 siver plus calculator
Shift [x^-1] allows you to access the matrix features. Under Names you select the names you want to use for your matrices. Under Math you access the various commands. Under Edit you edit the contents of your matrices.
Mar 01, 2016 | Texas Instruments TI-84 Plus Silver...
I need step by step instructions on how to work the TI-83 Plus
The calculator is a very advanced one. It has hundreds of commands, each doing something different. Do you honestly think that anybody, no matter how well intentioned, can possibly give you step by step instruction on how to operate the calculator? And for free.
TI publishes just such a guide book. It is freely available on their website at education.ti.com. Download the complete guide book, browse through it to look for the way to solve the problem you are studying. Be focused. Read only what you need, to solve the problem at hand.
However, if you have a more specific question such as how do add two numbers, how do I find the inverse of a matrix, or anything with limited scope, we will be happy to answer it.
Please formulate a question.
Oct 20, 2011 | Texas Instruments TI-83 Plus Calculator
How do i solve matrix equations on my calculator
This calculator does not support matrix equations/operations. You can either purchase a more expensive calculator with matrix functions, or you can do it by hand. Here is a basic tutorial on matrices: http://www.miislita.com/information-retrieval-tutorial/matrix-tutorial-2-matrix-operations.html
The TI-83 Plus is a calculator which will do matrix manipulation and is easily found used on sites like eBay.
Mar 01, 2011 | Sharp EL531WBBL Scientific Calculator
Solve a matrix of complex numbers using ti89 or any other ti calculator
Well, the equation is Ax=b and we want so solve for x
There are several ways of entering the data, but this is one way
Code: A=[15+35i 29+1i; 46+13i 62+3i]
b=[0;0]
x=A\b which has the trivial solution x=[0;0] (the ";" means "next row", a space next column.) To input a matrix use APPs then Data/Matrix Editor then New. Then change Data to Matrix. Put in the name such as "AA" in the variable field. Then enter row and column dimensions. Then edit as a spread sheet. Use F6(util) to delete a column or row. To manipulate matrices, exit the matrix application, then go to MATH then Matrix. Notice that J(RowOpps) is available. Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Texas Instruments TI-84 Plus Calculator
What does error #13 dimension mean on my TI-86 calculator, please.
Three possibilities:
1) You entered an argument with an inappropriate dimension.
2) You entered a matrix or vector dimension < 1 or > 255 or a noninteger.
3) You attempted to invert a matrix that is not a square matrix.
If you need further help, please specify the exact problem you're trying to solve.
Feb 10, 2010 | Texas Instruments TI-86 Calculator
When i attempt to differentiate an equation, the answer is a matrix, how can i get it back to normal, and get the actual answer?
I do cannot see how you can go from a scalar to a matrix. The only possibility is if your expression includes parameters , say A, B, or some such things that were previously defined as matrices.
If you had at some time defined a matrix (A or a) , have forgotten about it, and now you are using the symbol (A or a) as a parameter in a function you are trying to differentiate, the answer is bound to be a matrix.
I suggest you run the NewProb command, or in HOME folder, press [2nd][F1] (F6) [1:Clear a-z] [ENTER][ENTER]
I am no seer and I may have guessed wrong. If you still want to solve your problem, post a comment giving more information.
Jan 23, 2010 | Texas Instruments TI-89 Calculator
How do i solve a matric problem with a TI- 83+
You should try to use the correct heading.
Press [2nd][Matrix] right arrow to [EDIT][ENTER] to create the [A]
matrix. Exemple of a 3x3 Matrix [A].
Once the matrix [A] is created you press [2nd][MATRIX] -->[MATH]
You can add similar matrices, you can multiply matrices, subbtract them, raise a matrix to a power, extract the square root, etc...
Here are the other operations you can pefrorm on matrices. Sorry I cannot go into the detail of things;A minimun of theory is needed to be able to use the commands.
Oct 14, 2009 | Casio FX-115ES Scientific Calculator
How do i use my ti 84 plus to solve problems with the gauss jordan method, to obtain the cofactors of a matrix, and many oder operations with matrices
The matrix Math tools, are accessed by pressing [2nd][MATRIX] ->>[MATH]. Scroll the list to find all row permutations, etc.
Sorry but you will have to implement your Gauss-Jordan method yourself, and interactively.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
How do i multiply a (2x2) matrix by a (2x1) in the ti 89
The so-called (2x1) matrix is not a matrix. It is a vector.
Hope it helps.
Apr 26, 2009 | Texas Instruments TI-89 Calculator
IF I HAVE TWO equations 5x+8y=54, AND -9x+y=26 how do i solve
use the simultaneous equation solver software available on ur ti-89 and enter the equation in the form of augmented matrix and you will get ur answer.
Dec 03, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-80 Calculator Logo
97 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
