Question about Dell (58GGC) Motherboard
Aux pwr orange led on, computer not starting. Why?
  • mentormatt8 May 11, 2010
    This could be a sleep/hibernate problem. Try turning the system off then on and let us know what happens. Same symptom or different?
New motherboard will not power up. Power supply OK, No manuals or CD. Need pinout and label on Motherboard for motherboard to case connections for an ACER ECS EG31m V.1.0
[1 2 3 4 5 6 7]
[8 9 10 11 12 13 14]
[Orange White NU NU NU NU NU]
[Green White Blue White NU NH Green Orange]
NU = Not used/No wire
NH = No hole
1-2 HD
8-9 PWR LED
10-11 PWR SW
13-14 LAN
May 24, 2012 | Acer Computers & Internet
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Where is the fruse for the left aux power connector below the radio -
The fuses for the auxilliary power outlets are located in the rear fuse panel located under the left second row seat.
The fuse for the console and two front outlets is fuse #46 (20 Amp) and is marked "AUX PWR 1"
The fuse for the rear power outlet is fuse #15 (20 Amp) and is marked "AUX PWR 2"
Dec 01, 2010 | 2003 Chevrolet TrailBlazer
Front right led flashes 3 orange 1 green ,system starts to boot and then goes to a grey screen with curser i upper right corner and just sits there. i can just touch pwr button and computor shuts down
the flashing Orange and Green LED is a terminal battery failure:
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
The system not booting to the hard drive could be a HDD failure or a corrupt operating system. Boot to the XP CD, Press R at the 1st prompt to access recovery console, then run CHKDSK /R
Oct 12, 2010 | Dell Inspiron 5160 Notebook
Power outlets stop working
Check the following fuses in the rear fuse panel located under the left side passenger seat; AUX PWR 46 & AUX PWR 15
Aug 28, 2010 | 2005 GMC Envoy
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
I need assistance with the front panel cables (Power, HDD, Reset etc)
On your motherboard power is setup like so:
10 9 8 7 6 (no pin on 6)
1 2 3 4 5
1- HD_LED_P
2- HD_LED_N
3- RST_SW_N
4- RST_SW_P
5- RSVD
6- No pin
7- PWR_SW_N
8- PWR_SW_P
9- FP PWR/SLP
10- FP PWR/SLP
you have 5 connectors from the chassis' front (with cable colors):
-P LED (white)
+P LED (green)
HDD LED (yellow/white)
RESET (white/blue)
POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
Regards
Ashly
Feb 24, 2010 | Computers & Internet
Pwr Led blinks orange, with black screen (monitor is connected to computer)
Take off the monitor and hook up another known working monitor to the computer and turn the computer and monitor on. If the computer turns on with video then you know the original monitor is bad and would need to be replaced.
Jan 04, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Dell (58GGC) Motherboard Logo
1,007 people viewed this question
Alun Cox
