Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My hardisk 1tb only shows 500gb space, just bough it yessterday and i have installed it in port 0 and an other hardisk off 500 gb was installed on port 1 and when i go into my computer i only see both hardisks showing 500 gb
    Guru:
  • 597 Answers
If you're using the original XP version it wasn't able to format the correct size of the hard drives. You need to find a version with Service Pack 2 and boot off that CD in order to format the correct size of the drives. You could also boot off a Vista installation CD and format the correct size.
Posted on Oct 01, 2009
My laptop Model Compaq 5204NR I want to extend my hardisk. Is it possible to use External Hardisk for this model laptop. If it means how much can i use 1TB hardisk or which is suitable for this laptop....
This laptop will accept any USB harddisk as it does have USB ports.
I would recommend a 500GB personally as this is the most cost effective and most users are not likely to need 1TB unless using your laptop as a media center or video/music editing platform.
Feb 28, 2011 | HP Compaq Presario V5204nr Notebook
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Hardisk is not detcted on any computer
1.check the USB cord
2. the controller to the USB drive could faulty.
3.the usb port could be damaged / try another port.
***I hope this helps. Have a great day!***
Jul 10, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Hard drive on my computer is reporting 75MB left on a 20 gig drive with only word and a couple smaller programs on it - someone please give me an idea.
Hi!
Let's see how much left on your hardisk and how much space that your programs used in your disk..do this..
Double click the "My Computer" icon
Right click on your "Local Disk (C:)" drive and click properties...
The blue color indicator will tell you how much space was used by your programs on your hardisk..
The pink color indicator will tell you how much free space left on your hardisk
The capacity value should be more or less 19 GB..
See if this capacity value match in your drive..
If the capacity value of your drive is below 10 GB then my guess is you have a wrong setting for your hardisk... Look physically in your hardisk. Between the port of ide cable and power supply connector you will see terminals with jumper on it.. The jumper is used to short the terminal. the function of the terminal is to assign the hardisk as slave, master, cable connector and or limit the capacity of the hardisk to some amount.. Check the label of the hardisk.. schematic diagram on it will explain where to put the jumper...
If the setting of the jumper was correct and the capacity value of your drive match to approximately 19 GB... then I suggest you browse the files on your drive. Check all its sizes.. There could be movies there that eats your space.
I hope I explained to you everything you need to know..
Much appreciated if you rate this help.. thanks
May 22, 2010 | Maxtor Hard Drive
I have a black caviar 1tb hard drive but its only showing up as 127gb? ive tried it as internal and have now put it in external caddy but still shows as 127gb drive were as should be 1tb
Depending on your computer, if it is older, it may not be able to recognized and more than 127GB. I don't know anything about your computer, which makes this very hard for me to be more accurate. Try using it as an external on another computer and see if that changes things.
Older motherboards (before the massive Memory Increases 500Gb, 1TB) nover planned on it getting that high, so it was not in the programming.
Give that a try.. Sorry I could not be of more help..
Nov 05, 2009 | Western Digital Caviar GP 1TB Internal...
Hi, I have a Fujitsu Siemens 1TB Storage Bird. I do have 500GB of information stored. When you plug in the drive it looks like its connected properly on the windows taskbar. When i open My Computer the...
It sounds like your hard drive is all locked up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Computers & Internet
I have an Iomega MiniMax Hard Drive that was previously formatted for a Mac. It is supposed to be 500gb but when I format it for my PC it only shows about 234gb in the primary partition. How can I regain...
connect your harddisk to computer.
Then right click on my computer icon then click on "Manage"
then click on "Disk Management"
then find your removable device then you find unpartitioned space create new partition .then check.
Also check jumper settings of your harddisk.
It should not be on 16 bit or 32 bit in hardisk.
Jul 16, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
713 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
