Question about Sony KDF-E42A10 42 in. LCD Television
The TV resets itself every 30 seconds , I have turned it off I have also unplugged it and plugged it directly into the wall as well as change out surge protectors. the TV will be fine for a day or two then reverts right back. When it's on picture and sound are great.
  • 10,594 Answers
If it is Sony KDF-E42A10 TV then it needs new lamp.
How old is this TV and have you replaced lamp recently?
Lamp replacement procedure is written in user manual.
Let me know to provide you more info.
Thanks.
Posted on Oct 01, 2009
  • hharoonasad May 01, 2011
    i have same problem and i do replaced lamp about not even month ago
    i have same problem and i did chang a lamp around a month ago
Hi my TV bush 50/211f not turning on still standby red light, I m change supply board still problem today I am changing main board and turn on. light change to Blue 10 sek back red and again
try this Press and hold the on/ off button Whilst holding unplug the plug from the wall Continue holding for 30 seconds Plug in the plug whilst continuing to hold the on/ off button Continue to hold for a further 30 seconds And the screen should come back on, good luck
shaun
Mar 11, 2017 | Bush Televison & Video
When i turn on my tv it will automatically turn off by itself after 30 seconds.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 14, 2016 | Samsung UN46D6000SFXZA 46in Led Hdtv 1080p...
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
No picture light blinking
We recommend you remove all HDMI cables from the TV then unplug the unit's power cord for 30 seconds. Then plug the power cord directly into the wall. If the problem persists we recommend you have the TV evaluated by an authorized service center.
Mar 24, 2014 | Panasonic TC-32LX85 LCD TV
TV won't turn on no lights.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
I have a Sony KDS-60A2020. TV went blank. No flashing lights. I have sound, but the screen is blank.
have you tried a power reset, unplug all components from the TV unplug it from the wall, then push and hold the power button for about 30 seconds, then plug all components back in, plug it into to wall then turn it on again.
Jan 14, 2012 | Sony KDS-60A2020 60" HDTV
TV switched itself off. Standby light flashing on and off once then five rapid flashes. Tv would come on but then turn off again after a few seconds.Standby light even stayed on when tv switched off at...
Subject
Unable to Power On or Off the set
Symptoms / Customer Description
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required
Jan 02, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Simple power outage and I get no signal or internet connection.No lights on router.
First, the obvious: If the router is directly plugged into a wall jack, make sure the breaker for that outlet isn't tripped. If the router is plugged into a power strip or UPS try shutting these off and resetting them.
As to the router itself: Unplug the router from the wall jack/power strip/UPS for a minimum of 30 seconds. Make sure the modem you are linked to has been rebooted and then plug in the router power. It should reboot itself.
If it still fails to do so, I suggest you contact Linksys for further troubleshooting.
Aug 21, 2009 | Linksys Computers & Internet
MY TOSHIBA 46HM95 TURNS OFF BY ITSELF...
Sounds like earth problem with your Electricity. Your tv think there is some kind of a short then go in to protection. If i am wright, when you touch the ground and some applience, does it shock a little bit, if yes im wright.
Dec 15, 2007 | Toshiba 46HM95 46" HDTV
Sony KDF-E42A10 42 in. LCD Television Logo
184 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
