Question about Gigabyte Core 2 Quad Intel X48 FSB 1600 DDR2-1200 A&2GbE ATX MB-X48-DQ6 GAX48DQ6 Motherboard
Gigabyte GA-x48-DQ6 s775 ddr2 1066mhz cpu
cpu intel q9550
ddr2 corsair 4 gig 1066 2.1 volt ,cas 5,7.7.18
question how do you set the dram volts on Gigabyte GA-x48-DQ6
i want to run this mobo at 3,2 and the memory close to 1066 with a voltage of 2,1
what volts do i need for the Cpu also
thank you
  • 178 Answers
SOURCE: Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Posted on Mar 17, 2008
iqbal_del
  • 655 Answers
SOURCE: GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
Posted on May 14, 2008
map9966
  • 2351 Answers
SOURCE: Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
Posted on May 15, 2008
SOURCE: Gigabyte Slot 1 GA-6BXC Start Up UnStable
send me about all jumper on GA-6BXC and user manual version pdf
because i'm plug in PCI usb 2.0 ALI chipset M5273 and "system hang"please send me some solution about this problem...??
Email " didikratih20042003@gmail.com "
thank's
best regards
DIDIK
Posted on Jun 19, 2008
SOURCE: Windows fail to boot
How much power is the power supply? Could be the power supply not having enough power for your rig.
Posted on Sep 23, 2008
Pc beep code 1 long 9 short beeps = bios rom error
Your Motherboard is broken when the pc beep in that try to buy new one
Dec 03, 2013 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
What cpu is compatible with motherboard GIGABYTE GA-965P-DS3
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
Dec 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Problem Booting Motherboard After Overclock
hi unplug tour cpu chassis just remove the battery found on motherboard for 5 minutes then put it back inside
Jan 19, 2010 | Gigabyte GA-X48T-DQ6 S775 X48 ATX DDR3...
I overclocked my Gigabyte GA-X48T-DQ6 motherboard and now it won't boot
If you mean that nothing appears onscreen when you press the power button but you can hear the fans working then try this.
The quickest way to restore default bios settings is to remove the battery on the motherboard.
Important ..... Disconnect the power leads FIRST
Gain access to the motherboard and search for a small coin shaped battery. Note which way it fits into the holder, then remove it and leave the PC for 5 minutes. If you have a manual you can also check for jumper settings to discharge the bios battery.
Refit the battery (the correct way) and plug in the power lead. Cross your fingers and power up.
Can not copy a part of XP OS file
Hi there.
Go here to Gigabyte support and download the BIOS update you need>>>>>
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx?Keyword=GA-P35-DQ6
Good luck and thanks for using FixYa!!
May 26, 2009 | Gigabyte GA-P35-DQ6 Motherboard
Well my system temperature is reaching heats of 50oc under load and I believe it is making my computer freeze causing me to restart. I was wondering how exactly this temperature is measured and where...
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
Gigabyte motherboard driver
The problem is not with *********** Board. Check the front panel audio connectors inside your CPU are connected to *********** Board properly.
Sep 28, 2008 | Gigabyte GA-N680SLI-DQ6 Motherboard
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Hi Jay,
Luck!
Mike
Open Questions:
Gigabyte Core 2 Quad Intel X48 FSB 1600 DDR2-1200 A&2GbE ATX MB-X48-DQ6 GAX48DQ6 Motherboard Logo
111 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
