Question about Amana ATB1832AR Top Freezer Refrigerator
Defrost line is clogged - Amana ATB1832AR Top Freezer Refrigerator
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 01, 2009
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
My bottom drawer freezer is accumulating a sheet of ice
Your defrost drain line is clogged or frozen so the defrosted water is leaking into the freezer compartment and freezing into a ice layer in the next cooling cycle. Get your defrost drain line unclogged.
Sep 16, 2014 | Whirlpool Refrigerators
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
The fridge keeps freezing over
The evaporator coil is freezing, there could be a number of reasons.
a) drain line is clogged... defrost the fridge and shoot short bursts of compressed air into the drain to clear the clog
b) the defrost sensor on the evaporator coil is faulty... replace the sensor
c) the freezer is so PACKED as to impede air flow... stop stuffing your freezer
d) the defrost timer, defrost coil, etc. is faulty... replace as required
You could defrost your evaporator coil by turning off the fridge for several hours with the doors open, blow dryer, heat gun, etc... depending on skill level
Feb 27, 2014 | Refrigerators
Sanyo side by side door fridge is not defrosting, what to do?
bonjour,
Trouble comes in 3's
If there is never any water in the drip pan under the refrigerator it is not defrosting and the evaporator drain line may be stopped up. Side by Side refrigerators cool the freezer first and send a small amount of cold air to the refrigerator side. To start defrost the defrost timer stops the compressor and all fans. Next it turns on the defrost heater. This melts the ice/frost off the freezer coils. The water drips down the drain line to the drain pan under the unit. If the defrost heater raises the temperature too high the defrost termination thermostat turns the heaters off. When the defrost timer finishes it turns off the heaters and turns the compressor and fans back on. If the drain line clogs with food the water does not drain out and when the compressor starts again the water freezes. If this keeps happening the ice gets higher and bigger until it clogs the coils and the freezer does not get cold. If the defrost termination thermostat turns off the defrost heaters too soon all the frost is not melted from the coils. And the coils soon clog and the freezer gets too warm. No defrost usually means either a bad defrost timer, a clogged drain line, a bad defrost termination thermostat or some combination of the three.
If the drain line is not stopped up you can try this.
Remove all food from freezer and refrigerator, open the doors and unplug the cord. Wait 30 hours for all the frost to melt.
Keep the doors open and the cord unplugged the whole time. Empty the drain pan to keep it from over flowing. After 30 hours plug it back in and wait for 1/2 cup of water to turn to ice in the freezer. Then you can put the food back in. The problem can return if the unit is not defrosting. Or you can call a service technician.
Jul 11, 2012 | Refrigerators
Frigidaire Fridge (frt045gm) Not Cooling Well
Bonjour,
That's not a potentiometer you turned it's the defrost timer gear knob. What you were doing is aborting the defrost cycle and allowing frost or ice to build up on the freezer coils. It built up enough to clog the airflow and the temperature in the freezer started going up. The compressor seems to be operating normally.
Follow along through a defrost cycle
To start defrost the defrost timer stops the compressor and all fans. Next it turns on the defrost heater. This melts the ice/frost off the freezer coils. The water drips down the drain line to the drain pan under the unit. If the defrost heater raises the temperature too high the defrost termination thermostat turns the heaters off. When the defrost timer times out it turns off the heaters and turns the compressor and fans back on. If the drain line clogs with food the water does not drain out and when the compressor starts again the water freezes. If this keeps happening the ice gets higher and bigger until it clogs the coils and the freezer does not get cold. If the defrost termination thermostat turns off the defrost heaters too soon all the frost is not melted from the coils. And the coils soon clog and the freezer gets too warm. If the defrost heater is bad no frost gets melted off the coils and the airflow quickly gets clogged. No defrost usually means either a bad defrost timer, a clogged drain line, a bad defrost termination thermostat or bad defrost heater. You can take a chance and replace the defrost timer. If that's the only problem your back in business. OR
Remove all food from freezer and refrigerator, open the doors and unplug the cord. Wait 24 hours for all the frost/ice to melt. Keep the doors wide open and the cord unplugged the whole time. If the drain pan fills with water that's a good sign that the drain line is not clogged. Empty the drain pan often to keep water off the floor. After 24 hours the drain line should have stopped dripping water. If it's still dripping wait until it stops. Plug the cord back in, close the doors and wait for 1/2 cup of water to turn to ice in the freezer. Then you can put the food back in. The problem will return if the unit is not defrosting. Changing a defrost timer is not too hard. Unplug the cord. Locate the defrost timer. Take out the mounting screws and remove the part. Unplug the wires, plug them into the new part and remount it. Don't forget the ground wire if it has one.
Plug the cord back in and see what happens. If you did not defrost the unit turn that timer knob very very very slowly until you hear the compressor stop. Then wait to see if the drain line is dripping water into the drain pan. If it is your in business. If not either the drain line is clogged, the defrost heater is burned out or the defrost termination thermostat is bad and has the defrost heater shut off.
OR Or you can call a service technician.
Jul 11, 2012 | Frigidaire Refrigerators
Condensate line seems to be clogged. How do you
Usually the clog is at the top of the hose. you may have to open up the area where cooling coils are, let the ice melt then clear the drain. There could possibly be a problem with the defrost heater (which is in that same area) or the defrost themostat. But if your unit is trying to defrost, then if the drain is clogged, there will be an ice build up that the defrost heater cant fully melt before it goes back to the freezing mode.
Jun 10, 2010 | Refrigerators
I find water leaking inside my refrig. I do not have an icemake, and i can't locate any drain inside
remove contents in freezer and remove back panel then u will notice drain hole see if clogged or iced over if soo heat with hair dryer or unplug unit for 24 hours to defrost it ,,, sounds like a part in ur defrost system might be clogged, maybe thermostat bi metal, heater, defrost timer could be but first defrost it urself and clear that drain line from ice or obstructions hope this helps later mate
May 21, 2010 | Whirlpool Refrigerators
GE Model tbx18mazarww refridge. Water coming from behind the temperature control panel. Defrost line is not clogged
Your defrost line coupling , is blocked from inside the freezer , to the defrost line behind the refrig . You will have to remove the inside rear freezer panel and icemaker if equiped , and defrost the drain hole in the center below the coils . Hot water will help .
Sep 24, 2009 | GE Refrigerators
Defrost water leaking into lower section through cold air vent
It sounds like, that the water drain hole or drain line is clogged. It could be clogged with food particles or ice. You'll have to thaw it out and clear the hole or line. Good luck.
Jul 13, 2009 | Refrigerators
Amana ATB1832AR Top Freezer Refrigerator Logo
159 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
