Question about Dell Laptop Keyboard Unit with pointing stick ( 87 Keys ) - 71EDM
Dell Latitude D620 Pointing stick will only move mouse pointer to left & right. No longer has vertical motion. Worked fine until yesterday. Have made no changes to the system before problem started
  • 832 Answers
Just replace your mouse, with the same model. It could
be defective.
Posted on Oct 01, 2009
How to re install firewall for windows xp
Click Start/Control Panel/Administrative Tools then click Services. Put your mouse pointer between the columnar headings of Name and Description until it turns into a + then hold the left mouse button and drag the to the right so you can read the entries under the name.
Scroll down under the name column and find "Windows Firewall/Internet Connections Sharing (ICS) and double click on it. When the window opens under the General tab the Startup Type should be set to Automatic, if not change it to Automatic and click Apply, then OK.
May 08, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Touchpad/Pointer do not function when pressed/glided ...Dell Latitude D410 w/ Windows XP Facts / what i've done: 1. BIOS - is set to use both Touchpad and external USB mouse 2. Turn computer off &...
Hi! Welcome to www.fixya.com.
You can try to download the Alps driver in this Link; http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If nothing happens after reboot: Its definitely a hardware issue. You have to call out fo warrant department your manufacturer so it will be fix.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 26, 2011 | Dell Latitude D410 Notebook
I need to disable Dell Latitude 620 track stick. It's not listed in the device manager and I HATE it.
If I get what your talking about go into mouse and pointers there you can change the right click left click around and a bunch of other options.
Jan 13, 2010 | Dell Latitude D620 Notebook
My dell latitude 610 touch pad is extremely slow
Try changing the pointer speed of your touchpad:
1. Go to Control Panel
2. Select Mouse
3. Click Pointer Options
4. Adjust the motion speed to fast (whichever you prefer)
Hope this helps.
Dec 07, 2009 | Dell F3534 Touchpad
Keyboard dell d600 latitude
in control panel click on mouse. click on the mouse pad where the pointer is pointing. top left you see "device settings". open and go to pointing stick. click disable.
Jan 12, 2009 | Dell 0Y3740 Keyboard
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
151 people viewed this question
Alun Cox
