Question about HP LaserJet 2300 Printer
49.4c02 service error - HP LaserJet 2300 Printer
  • 81 Answers
An internal firmware error has occured. Could be down to a faulty memory module installed in the printer the an optional EIO card you may have installed in the printer
Posted on Oct 13, 2009
  • pamelashalle Sep 13, 2010
    could you be a little bit more specific for those of us who don't understand computer language?
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
The printer will not print because of service error 49,4c02
Hello thanks for using FixYa
error 49.4c02 is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
Please see my this Solution (Same as your's), 2 people thought it as Helpful for them So
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 10, 2011 | Office Equipment & Supplies
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Message is Service call error 00010014
SERVICE CALL 00010014
Description
Failure of pressurizing
Nov 21, 2009 | Epson Stylus Pro 9800 InkJet Printer
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
to abort operation. This type
of error can be caused by
corrupt data, or invalid
operations. In some cases,
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
programs and print jobs,
disconnect all of the
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
off and on again as you
install each device.
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
HP LaserJet 2300 Printer Logo
754 people viewed this question
Seeker5211
Seeker5211
