Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
How to adjust volume - which button do I use. Nothing works
Please don't email me again. I have resolved the issue. Thanks
Posted on Oct 02, 2009
Volume does not adjust, when pressing the volume button up or down, jabra bluetooth tells me the status of the battery, but won't adjust the volume up or down
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Feb 23, 2013 | Jabra Extreme2 Bluetooth Headset
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
Just turned the TV on and the volume won't work. Have tried to manually turn it on, use the cable box and adjust the audio settings and nothing will make the volume work.
Memory Initialize operation
NOTE: The execution of this function returns the adjustment codes to the preset values, therefore, adjustment
data will be lost.
Procedure
(1) Enter Adjustment Mode.
(2) Select MEMORY INIT adjustment code (No.704) and change the data value from 0 to 1.
(3) Activate MEMORY INIT by pressing OK button for more than 3 seconds.
(4) Select No.374 and change data value from 1 to 0.
(5) Check that the receiving channel goes to AV1. Unit is set to preset values
Dec 28, 2010 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I have volume but cannot adjust it up or down.the + & - buttons click when pressed but nothing happens and there is no green volume bar on the screen when using the slide control.
Try looking for a button on keyboard that says FN hold this down then try press .the + & - buttons
The FN key i like a a acitvator key you can adjust manually bye clicking on speaker in lower right corner as well
Dec 21, 2010 | Computers & Internet
I have an 17" (2 in1) n Tru Tech LCD TV (with built in DVD player) The volume can not be adjusted, whether I is the remote or volume control on the TV. It goes to#15 and stays at that volume. What Can I...
I assume "#15" is the displayed volume setting on the screen when you try to adjust the volume. Is this the maximum? If so, perhaps the front panel volume up button is stuck on (not the remote control; nothing else on it would work if that were the case).
Another likely cause is the TV's microcontroller chip or memory chip that goes with it has a fault in its volume control address location.
You can check for a stuck button by comparing its feel with the volume down button when you press it. If it is stuck, the difference in action will probably be noticeable. If you can't tell any difference, the set needs internal repair.
Oct 22, 2010 | Televison & Video
Radio on the fritz
just try and pull out the radio and try reconnecting all the wires
Feb 24, 2009 | 1997 Volkswagen Jetta
W220 hearing problem!
The internal screen settings only adjust volume of ringer, the external button on side adjusts ear piece/hand set volume.
If the volume buttons do not turn up the volume of the hand set then the handset is defective
Mar 27, 2008 | Motorola Mobility W220 Cellular Phone
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Volume control buttons on Creature II speakers
this problem is bcoz of the buttons only it require servicing see if you can show to service pesonnel he will help you out.
Sep 07, 2007 | JBL CREATURE II Computer Speakers
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
