Question about Samsung Jet S8000 Cell Phone
Unable to set Daylight savinf time for london in samsung Jet S8000. The time is not changing when we select daylight on or off
SOURCE: how to remove/ change a wireless point on samsung s8000 jet?
Just had the same problem.
Go to Settings, Application Settings, Browser Profiles, pick the network you want to change by clicking on the double arrows to the right of the network name. That should let you change the password.
Posted on Aug 31, 2009
270rexton
  • 762 Answers
SOURCE: My Samsung S8000 jet restarts all the time after i
Take out battery for 30 min, then reinsert.
Posted on Sep 21, 2009
1986praveenk
  • 108 Answers
SOURCE: on the samsung jet how do you change the message alert tone an
Hello Sir, For this you need to go to Profile menu. There on your preferred profile, go to the menu which personalizes the profile. There on Message sounds, you can change the volume, tone, vibration intensity ( if you use ). But you have to do it to all the other profiles which you want to personalize. Ex. If you want it on Normal and on Outdoor, you need to do the same task on both separately.
Thank you Sir, Have a nice day.
Posted on Jan 09, 2010
asber
  • 291 Answers
SOURCE: Samsung Jet S8000 Cell Phone how to Restore
Remove your sim card and sd card, and type this to your keypad, *2767*3855#
Posted on Feb 17, 2010
SOURCE: How do I set my speed dial on my samsung S8000 Jet
  1. Select Phonebook
  2. Choose the "Favourites" drop down in the top right
  3. You get the interface where you can click on a number and assign a contact (on my phone #1 is locked to messages).
Posted on May 11, 2010
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Phone not changing time with daylight savings time. howto update the time
In Standby mode press 'Menu' then 'Settings'. Select 'Set Time'. There you can manually change your time. Here is a link to the manual: http://www.phonesir.com/Samsung_SCH-r350+Freeform_manual.html#
Mar 13, 2011 | Samsung SCHR350 Freeform rubberize...
Setting up Samsung 32 in HDTV On the clock setting screen for Daylight Savings Time - do I choose On or Auto? I live in California. Thanks.
Try AUTO.
When Daylight Saving takes effect you can go into setup CLOCK and click DST on.
When Daylight Saving ends you can go into setup CLOCK and click DST off.
Feb 13, 2011 | Samsung Televison & Video
How do you set the time on a c340?
Question: The time is not correct on my StreetPilot. How do I set it?
I think one of these 2 may help you.... --> Answer: The GPS unit acquires the time from satellites. Therefore, to display the correct time, the StreetPilot first needs to acquire satellites. You can then set the time zone and daylight savings time.
To set the time zone and daylight savings time:
  1. Press the Menu button two times.
  2. Select System Setup.
  3. Select the Time tab.
  4. Select the time zone and daylight savings preference.
Oct 23, 2010 | Garmin StreetPilot c340 GPS Receiver
4420 set to Central Time with Automatic Daylight applied reverts to Standard Time at power on ... has Daylight Savings not been applied ?
From the Start menu, select Settings >
Control Panel > Date/Time
to open the
Date/Time Properties control panel.
Use the arrows in the application to
navigate, increase or decrease the
time or date.
2. Select the year to open a field where
you can change the year by backspacing,
or entering a new year.
3. Select the month to open a pulldown
list of months.
4. Tap the checkbox to enable the Automatically
adjust clock for daylight savings
time
, if desired
Mar 17, 2010 | Datalogic Falcon 4420 Handheld Barcode...
How to set the current time.time did not change when we turn the clock back one hour.
either your 1440 was never set to include daylight saving time or the unit was reset at some point.
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go to the main menu, then system option and click on the time zone tab, then select your time zone and check off the little box for daylight saving time.
bill
Nov 06, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Samsung Impression :Daylight savings time moved all the appts
This is the second Samsung phone I have had that did this. The A707-Sync had the same problem. I called Samsung tech support and they told me to disable the auto-update feature for daylight savings. Not a great solution, but the only one I got.
Nov 02, 2009 | Cell Phones
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Samsung Jet S8000  Cell Phone Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
