Question about Garmin nuvi 260W GPS Receiver
Sound disappeared from nuvi 260
Volume all the way up already check mute still nothing
  • Garmin Master
  • 2,130 Answers
Most likely a dfective speaker. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Posted on Oct 01, 2009
My garmin wont talk
Select another voice - if nothing upload a new voice such as the free voice:
http://www8.garmin.com/vehicles/voice.html?vName=DrNightmare
Select this voice and plan a route. If still nothing check the basics such as volume or volume mute.
Jun 30, 2011 | Garmin nuvi 200W GPS
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
No sound
First check if your nuvi is not on mute by touching the button next to the volume that reads mute, then you try to increase the volume. To increase the volume:
  1. from the main menu,
  2. Touch the volume,
  3. Then you adjust it with the left and right direction button to increase it or reduce it.
If that does not solve the problem, then you need to reset the nuvi, by holding the power button for about 15 seconds. It will restart itself. Or you can remove the battery and install it back in. If that does not solve the problem, then it is an internal problem.
Dec 29, 2010 | Garmin GPS
How do you get the sound to come back on your garmin nuvi
ok a few things to check here....
make sure its not muted... press your volume icon make sure no checkmark in it.......
if you have Traffic make sure the FM Transmitter is not muted
next check Tools.....Settings......Language.... under Voice tab make sure you have selected one that ends with ( TTS ) text to speech
Nov 19, 2010 | Garmin nuvi 200W GPS
Dell Studio 17 windows 7/ Sound disappeared completely.
The best thing to do would be a system restore. You might have installed some software or changed some settings which made the sound disappear.
Click on Start>All Programs>Accessories>System Tools>System Restore and follow the on screen instructions.
Jul 22, 2010 | Dell (8H390) Sound Card
Garmin Nuvi won't talk. No sound when programming
If the mute is not checked, try plugging in a set of headphones. if you now hear sound, your internal speaker is blown. Please see this link:
- Jim
Apr 27, 2010 | Garmin nuvi 750 GPS Receiver
We have no verbal direction on our garmin nuvi 260 & it is not on mute. This Garmin is 1 yr old & we have not had this problem in the past. It has not been used for awhile & when we plugged it...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites
Nov 01, 2009 | Garmin nuvi 260W GPS Receiver
I updated my nuvi 265T, now no sound, long load times and extremely short battery life. Can I go back and un-update?
same here, I talked to tech support and they said I will have to send it to their kansas office and they will give me a new one.
Oct 15, 2009 | Garmin nuvi 265 Car GPS Receiver
Just bought a garmin nuvi 265t. Sound and blue tooth not working
i have same problem. volume goes out - often with bluetooth connection. i THINK it THINKS I'm making a phone call so automatically mutes. Checking MUTE on or off does not work. Seems that if I power down and up, or best yet power down for a bit - volume is restored and bluetooth link (which sometimes disappears) enables again.
Jul 18, 2009 | Garmin GPS
Garmin nuvi 260W GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
