Question about Sony RM-AV2500 LCD Touchscreen Remote Control
How do I retune my televison with the different channels using the remote control? I can't seem to do it.
    President:
  • 1,653 Answers
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Posted on Oct 03, 2009
SOURCE:
I decided to re-tune all the channels. Now I have only half the channels. I have tried to re-tune, with the same results. Manual re-tuning will not accept the wanted channel numbers. Please help.
It could be a signal strength or signal quality problem - too strong a signal is as bad as a weak signal.
Retuning using a different aerial with a known performance would prove that. Once retuned with all channels present and stored in the memory you should find the original performance using your own aerial is restored.
Sep 08, 2017 | Televison & Video
Got a one for all remote control looking for codes so I can use it to retune my freeview box which is sagem make
If your One For All remote is universal, you can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 27, 2017 | One For All Televison & Video
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
Lost all programs need to retune How
  1. Scan the channels
    1. Press the Menu button on your remote control.
    2. Select Channel and press OK on your remote control. For Aerial you must choose the Cable option.
    3. Go to Auto tuning and press OK twice on your remote control.
      - Set the Automatic tuning screen to Cable (vertical) and Digital (horizontal). - Then press OK on your remote control.
    4. Enter the following values:- Search mode: Quick- Network: Manual- Network ID: the code for your region (22 for Flanders and 12 for Brussels)
    5. Press OK on your remote control.
    6. For Frequency enter the value 322000 and press OK on your remote control.
    7. For Modulation enter the value 256QAM and for Symbol rate enter the value 6875.
      Then select Search (or Next, this differs by type of TV) and press OK on your remote control.
    8. Your TV now scans the channels.
Jun 02, 2015 | Samsung Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I work in a hotel and i am having problems with my nec -26xt2 tv.channel7 &9 they are coming up with a blue screen .ihave tried to retune the tv taken off the child locks with usual remote but when i...
Hello Maintenan5,
The Term "I WORK in a Hotel" and "My TV"
are not compatible terms...
- your model number is not complete
- Obvious CONTROLS have been implemented.
Before I would EVER actually tell you even IF
you could DEFEAT security features : you NEED
to AUTHENTICATE
you have AUTHORITY &
PERMISSION to be tampering with OWNER
CONTROLS
(because this question reeks
of impropriety).
Then I would be delighted to resolve your issues.
Hope this saves your "employment"
Carnac the Magnificent
Sep 16, 2017 | NEC Televison & Video
My PVR has retuned (DSO)to the wrong transmitter. I receive signals from the Winter Hill transmitter and live in SW Cumbria. My Humax 9200T has retuned ok but my older 8000T has retuned to a transmitter in...
Not a complete solution but after much fruitless fiddling through the menu I eventually found that the programmes were actually there but under different channel numbers.
I searched a long way down the LIST of channels (on remote) The BBC1 channel I want is now 800 BBC. Selecting 1 on the remote still brings up BBC Wales.
This applies to my Humax 8000T PVR - I can't comment on other makes of Freeview box.
Nov 05, 2009 | Televison & Video
Sony RM-AV2500 LCD Touchscreen Remote Control Logo
411 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
