Question about Refrigerators
My Kenmore refrigerator coldspot #70192001 is not defrosting correctly and water is leaking from the freezer down the back wall and turning in to frost under the bottom tray in the freezer. Water is also running down the inside back wall and accumulating in the bottom inside of the refrigerator and turning to ice. HELP!!
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
I have a kenmore elite side by side refrigerator coldspot model 50599003. It is leaking water from somewhere underneath..I was.told it could be a water valve..It is not leaking from the supply line...
Are there 3 numbers missing in that model number? Something is missing in that model number somewhere. This could be several possibilities causing the water leak. A defrost condensate pan may have a crack or the union just behind the kick plate going to the dispenser from bottom of refrigerator may be leaking. Or this could be the result of a defrost drain blockage inside the freezer having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
The model number should be like this=> 321.236589 Let me know if you can because that number is not coming up, Thanks Sea Breeze
Dec 09, 2012 | Refrigerators
Kenmore coldspot 70192001 is not making ice and refrigeration doesn't seem to be cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 14, 2011 | Kenmore 14.8 cu. ft. Top Freezer...
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the...
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Sep 11, 2009 | Kenmore Refrigerators
I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Jun 30, 2009 | Kenmore Refrigerators
Water leaking inside the refrigerator
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
800 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
