Question about Sony Cyber-shot DSC-W50 Digital Camera
I accidently pressed create R.E.C folder button
I accidently pressed the create R.E.C folder button and now when I press the button to View images (on face of camera) it says no images!? But they are still there because if I press Menu and then go to Image Index then they are all there! Someone pls give me some advice, it is really annoying!
Love Bambii x
Creating folders on sony sc-h7
Try this:
Press the "home button". Press the right button three times so you are on the memory tool area. Then press the center button. Then press the right button and then press the down button once to get to the "Create Rec. Folder" and then press enter. Now you have a new folder.
To switch to a new folder, click on "Change Rec. Folder". Now any new pictures you take will automatically go into the new folder you made/selected.
Aug 13, 2012 | Sony Cyber-shot DSC-H7 Digital Camera
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Pics gone in DCIM folder. Using a Nikon s3000 coolpix camera, connected to computer, F:\s3000 is detected, within it is DCIM folder present, and within DCIM folder presents Nikon100 and Nikon101 folders,...
You cannot create new folders on an SD card and copy images to them, as the camera will not recognise them, since they were not create in the camera. Copy the entire contents of the card to a folder on your HDD, then format the card in the camera.
Mar 18, 2017 | Nikon Coolpix S3000 Digital Camera
I have 1200 photos on my memory stick. Is there any way I can wipe out the whole stick instead of having to delete them one by one?
Press the Playback button(the one to view pictures) then select menu. Select the delete(trash bin) and press the right/left arrows and select all images in this folder. Then press the circle button to confirm.
Hope this works.
Apr 24, 2011 | Sony Cyber-shot Digital Camera
How to delete pictures?
To delete the images from the Camera, press the Play button on the Camera to view the images. Display the images which you want to delete and press the DELETE button (Recycle Bin icon) located below the lower left of the Control buttons.
To delete multiple images, slide the index lever and select with the control buttons.
While the index screen is displayed, press the Delete button and select the images with the control buttons and select Enter button. Now, select the images which you want to delete and press the Enter button to display the Delete icon on the images. Press the Delete button again to delete all the images.
You can also delete all the images in the folder by selecting All in this Folder to delete the images.
To delete all the images in the Memory Stick you can select the Format option from the Internal Memory Tool or the Memory Stick Tool Menu to Format the Internal Memory or the Memory Stick.
Thanks for using FixYa.
Jan 27, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
Cant seem to be able to download music onto it off computer didnt get any instructions with it
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer step 2 Press the home button on the PSP step 3 Use the left and right buttons to find Settings ( select by pressing the X button ) step 4 Select USB Connection -Your computer will notify you that a new USB device has been connected This should show up as a new hard drive with a corresponding letter identifier step 5 On your computer, select the correct drive letter and open PSP file system step 6 Create a new folder and call it PSP step 7 Go inside this new PSP folder and create another folder. Name it MUSIC step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created step 9 Disconnect the PSP from your computer by pressing the O button step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC - Select Memory Stick by pressing the X button You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP. http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
All the best to you my fellow PSP enthusiast.
Jan 26, 2011 | Sony PlayStation Portable (PSP) Slim...
How do you format a RCA Digital Voice Recorder with Model# RP 5016A?
It has been some time, but if I remember right.
Insert (up to 256Mb) SD card in slot.
Turn the unit on (Press hold > (PLAY button)
Press Menu button
Use >>| (FastForward button) to select from "INT"ernal memory to "EXT"ernal memory
Press STOP button
A message "WAIT" will be displayed.
If I remember correctly, it will ask to format if it needs to. (Use >>| (FastForward button) or |<< (FastRewind button) to select "YES" or "NO".
You can alternately use a PC to format as FAT (Not FAT32) file system.
As you use the unit, it will create FOLDER1....FOLDER9. In fact it will create each folder, each time you go to view any of the 9 folders that aren't already there. Until all 9 folders are created.
I haven't had to format my 256Mb SD card. I just inserted it, and it was fine. (Even ones I had previously used with other data, the DVR will simply create folders "FOLDER1", etc. if not already there, and use them. )
Nov 05, 2009 | RCA RP5016 Digital Voice Recorder
Lost cd rom
You can use the Camera without the installing the software supplied on the software installation disc.
The simplest way to transfer the photos from the Camera to the Computer is to connect it to the USB port of a Computer then follow the following steps:
1. For Windows Computer:
(a) as soon as the Camera is connected the computer recognizes it as a removable drive.
(b) open the windows exlorer by pressing the "Windows + E" key together.
(c) locate the removable drive in the windows explorer that represents the connected camera.
(d) double click the drive to navigate through the files and folders, then double click on the DCIM folder to view all the images.or navigate through other available folders to check if the images are stored in them too.
(e) select all the desired images then copy them by pressing "CTRL+C" then paste them on the hard drive of the Computer by pressing "CTRL+V".
2. For Mac"
(a) as soon as the Camera is connected the computer recognizes it as a "NO NAME" folder and display it on the Desktop.
(b) double click the "NO Name" folder to navigate through the files and folders, then double click on the DCIM folder to view all the images. or navigate through other available folders to check if the images are stored in them too.
(c) select all the desired images then copy them then paste them on the hard drive of the Computer by using the copy and paste operation.
Furthermore, you may use Windows Fax Viewer, Windows Photo Gallery or Windows Movie Maker to view and edit images in Windows and iPhoto in Mac.
Oct 10, 2009 | Oregon Scientific DS6618 Digital Camera
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
How to use my external USB hard drive
IF you want to back it up
in the above list you made, click view all files in folders
then highlight all the files and to the left it should say Burn To Disk
click on the burn to disk and follow the on screen instructions
Hope this helps
if not write what other trouble it has
Thank you
Fixa fan
Oct 30, 2008 | Computers & Internet
Sony Cyber-shot DSC-W50 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
