How do I set a Crystal 11 report to fail w/no data?
I'm generating a daily report and emailing the report to the clients. If there was no activity for the day and there is no data for the report, is there a way to cause the report to fail when there is no data? We have already set the report to say 'No activity" instead of a blank report. But now we want to know if there is a way that we can get the report to not generate all together if there is no activity. (No email distribution) The report is not printed, only emailed in PDF format. I am not a computer programmer, I am an accoutnant and have recently only started using Crystal 11. I am helping out the IT dept, so I need layman's terms and step by step. Thanks!
i am also experiencing this problem. what i did was i created a new file in the repository folder (in crystal, when you create a new connection), containing the script that will pull all of my needed data.
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
In visual studio 2005 or 2008 crystal reports is present inside so right click in the project and add new item and select crystal report(.rpt) and select the database samething like gridview connectivity and select the table select row and columns of the table now u r crystal report is ready
