Portable Televisions
Problem for Portable Televisions
Generic problem for all Portable Televisions
Delayed Power Up
By prowln on Dec 21, 2007
I have a 13" RCA color tv that has a delayed power up....but, if i unplug the cord and plug it back in, it comes up. How can i fix this? It is not much but i was wanting to give it to a nursing home resident, Thanks in advance
Comments:
Dec 21, 2007
- Hi...thanks for responding. This unit is a 13 inch RCA. Manufactured Jan 1996. Model # is E13201OK (the last 2 letters were hard to read...and may not be correct).
120 ac volts
60 hz
70 watts max
chasis # TX825TB
Dec 28, 2007
- Why is the transistor difficult to replace? Should i just trash this unit?
Dec 28, 2007
- and, is the TP15 and the DP02 marked on the circuit board?
Best Solution
posted on Dec 21, 2007
Very Helpful)
Terryfic
Rank: Guru
Rating: 87%, 1707 votes
Probable regulated 12v power supply.....To help further....need
info....Model # and service # and mo /yr built off back of set..T.
Comments:
Dec 21, 2007
- Requires difficult replacement of transistor TP15 and diode
DP02.............RCA part # 198752 sub 185197 or generic
and a common 12v zener = SK12A or ECG5021A............T.
Dec 28, 2007
- Part locations clearly labeled on board..difficulty in basing configuration...transistor base, emitter and collector need
special alignment with substitute.....original no longer available.
Dec 28, 2007
- Thank You for the FixYa rating ! Let me know if you need further assistance.................T.
Rating Locked! (?) prowln has rated this solution as Very Helpful
Popular Solutions for Portable Televisions
Questions and Unsolved Problems for Portable Televisions
Answer
High tension is not running TV Spectra model CE-5488
Answer
Today I bought the Haier LCD tv HLT71 and when I tried programming it, it said "no... (More)
Answer
television starts for around 20 seconds the goes off and will not restart untill disconected rested... (More)
Answer
how can i connect between my laptop and TV
Answer
need to have vert hold replaced but tech is to busy where is it so that i can purchase on my own.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Portable Televisions:
Top Portable Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Portable Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
