Intex Automatic Salt Water System for  Above Ground Saltwater Pool
Problem for Intex Automatic Salt Water System for Above Ground...
Intex Deluxe Saltwater System & Filter Pump
By ljefford2 on Oct 01, 2009
Intex Deluxe Saltwater System & Filter Pump Model 8111. I plug the pump in turn it on. The pump comes on, then runs about 3 or 4 min. the LED pump light and code numbers start flickering then the system shuts completely down. within seconds the system will flicker back to life then shut back down again.
Tryed to contact Intex, but no responce at all.
I have checked the outlet everything is good. I have checked all connections inside and out of the system and I do not see any problems. any sugestions of where to look?
Solution #1
posted on Oct 03, 2009
Not Rated)
kieranj459
Rank: Guru  Garden Tools  Expert
Rating: 87%, 80 votes
Check to be sure the filter and baskets are clean, as you need proper water presure to have unit run.
Was this helpful?
Yes
No
Popular Solutions for Intex Automatic Salt Water
Questions and Unsolved Problems for Intex Automatic Salt Water
Do you recommend Intex Automatic Salt Water System for Above Ground Saltwater Pool?
Answer
Answer
Intex saltwater 8100 was mowed over. There are three wires. Does anyone know how to rewire the... (More)
Answer
intake on the pump is pulling air from the values in the pool has anyone else had this problem and... (More)
Answer
I have an intex 8110 chlorinator that I bought last spring. It was working great until a month ago... (More)
Answer
i have the same deal. Suddenly the unit is not making chlorine. Seems to be plenty of salt. No... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pool and Spa Pump Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
