Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
Posted on Dec 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clicking sound & not seen
Drive worked fine till it fell off the table (2feet) onto carpet but now just clicks slowly and does not get seen by the pc. no visible damage to case, just out of warranty ...doh !!!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
54
Points
Mine does the same thing but the bios did find it? what should i do now
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Dec 24, 2007
Anonymous
Expert
Level 2:
Answers
70
Questions
0
Helped
72912
Points
124
Does BIOS detect the hard drive? if not then it has conked off. Buy a new one.
  • Anonymous Dec 24, 2007
    You can also
    check this by Right click on taskbar > properties > startmenu
    > customize > advanced > scroll down completely and select
    system administration tools "Display on the all programs menu" > ok.
    Click on start > all programs > administrative tools >
    computer management > double click on storage. click on disk
    management(local). Is your hard drive detected?
I dropped my usb hard drive when it was not connected. It slipped out of its leather pouch and fell from my work desk onto the office carpeted floor. Now it doesn't get detected by my notebook. When...
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
1helpful
Hi, unfortunately my Wii fell onto the carpet last
i think that the laser inside the disk drive has skipped
lets say the laser moves from a to b (a is the start)(b is the end)
the laser might of jumped to b but the console still thinks it is at a and it keeps trying to move it towards b but it cant go any further because the laser tracks stop
you could open the console up and test the drive or replace the disk drive
Accidental fell from table onto the carpet.We cannot get our pictures to come up onto the computor is there anything we can do
If it was running when it hit the ground, then it's probably busted. There are many specialty companies like OnTrack that can recover data, but it's expensive.
My hard drive was knocked of the table and landed on carpet
Computers do not like being dropped especially when it is powered up and running. It can do a heaps of damage.
If the hard drive in the computer makes a clicking sound and it won't boot up and/or an error message says it cannot find the hard disk or operating system, then the hard disk is damaged beyound repair.
With luck if the hard disk is only damaged then you can replace the hard drive and install Windows on the new hard drive with the device drivers and your programs. Your data on the old hard drive is gone unless you backed up your data onto CD, flash drive etc.
Odd clicking noise...
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
1helpful
Archos not seen by pc
This can happen to any external drive on a pc. If the Archos is set to PC Hard Drive mode, then plug it into you PC and click Start, click Run, type compmgmt.msc, and then click OK.
In the console tree, click Disk Management.
You can now allocate a drive letter to the Archos.
If you cannot see your Archos in this window, then you may have a dodgey usb cable.
Unresponsive harddrive
hi,
you have definitely got a dead HD (hard-drive) there, nothing you can do about it.
sounds like the force of the shock has damaged the HD beyond repair.
HD work by i high precision arm that reads data on a spinning platter, the chances are you have damaged the arm and the click is where the arm is trying to read the HD with no luck
sorry
Fantom Drive problem
Try connecting it to a Windows XP Pro pc. Right click on "My Computer", left click on "Manage". Once the new management console opens, left click on "Disk Management". If the USB drive is recognized by the pc, you will be able to right click on it, and select "Delete Partition". WARNING: YOU ARE DELETING EVERYTHING ON THE DRIVE! Once it's done, right click on the drive again, and select "Create New Partition". Proceed thru the wizard that pops up, and format it. You will have a choice of using FAT32, but, if the partition is larger than 32 GB, it will fail (it's a Windoze limitation), so NTFS is your only choice, unless you use a 3rd party utility, Win98 (supports huge FAT32 partitions, 4 TB, I think), or Linux.(preferred). Good Luck, hopefully everything will work out fine. T-Power
13helpful
10answers
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
