Question about Sewing Machines
I have a Singer Stylist 834, have rethreaded and several times and it will not stitch. It acts like its sewing but there are no stitches. Please advise.
  • 208 Answers
It sounds like your machine has a broken vertical shaft gear.
Open the slide plate and, while turning the handwheel, look to see if the hook is turning under the bobbin case. If not, take it to a repair person and it should cost around $100 to replace the gear.
Posted on Oct 01, 2009
How to change needle position (left, right, center)
Which stitch are you using? As far as I can tell, the Stylist 7258 only allows you to change the needle position for straight stitches. If the machine is set to Pattern 00, press the right or left buttons from the 4 arrow keys in the manual setting arrows until the needle is in the desired position.
For all other stitches, the left/right arrows adjust the stitch width. This is described on page 30 (in English) of the manual. You can download the manual from the product page under the support tab: http://www.singerco.com/products/2101/7258-stylist#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/4951b452e963a8fe1dd1fd83fbac68a35df8cf19.pdf .
I hope this helps.
May 23, 2016 | Singer Stylist 7258 Electric Sewing...
Where do I take my sewing machine to get fixed?
sadly we have no idea where you live , so we can not check for you. try the singer website at singerco com
May 13, 2016 | Singer Sewing Co 7258.CL Stylist Sewing...
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
Jan 04, 2013 | Sewing Machines
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
I have an old Singer Stylist 834 I am having problems as the under side of the simple straight stitch is loose and has tons of cotton tangled in a big mess ! Help ?
Mostly what causes that problem is incorrect threading of the upper tension. If you rethread, then pull the upper thread as you lowerr the presser foot there should be a big change. Foot up...little or no drag on the thread. Foot down..it should be tighter, almost enough to break the thread.
The other stuff to look for is.......marks on the needle plate that catch threads, a rough or misaligned bobbin case.....poor quality or too big a upper thread.
Derek
Jan 17, 2011 | Sewing Machines
Sewing Machines Logo
289 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
