Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon printer pixma mp780 makes repeated clicking noise but will not work. Shows ##356 on LCDisplay
    President:
  • 1,653 Answers
This is the Automatic Sheet Feeder [ASF] Cam Sensor Error
Movement may cause the plastic guide to move away from the chassis which causes the gears not to rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356 (MFP) - ASF Cam Sensor Error.
Remedy: Adjust the Screws & Main Case Unit
Step 1: Remove the Left & Right Covers and the Main Case Unit (main cover).
Step 2: Remove the 4 mounting screws from the Chassis.
Step 3: Remove the Main Unit from the Bottom Case.
Step 4: Turn the Main Unit over (upside down) and place on work surface.
Step 5: Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis. The size of the gap varies. Even if the gap is not visible, complete the steps below.
Step 6: Disconnect the appropriate cables and remove the Logic Board from the Chassis.
Step 7: Loosen but DO NOT remove the 4 mounting screws which can be located behind the logic board on the Chassis.
Step 8: Reseat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic guide should sit slightly inside the mounting screw hole. When seated correctly, the gap will no longer be present.
Step 9: Tighten the 4 mounting screws without causing the plastic guide to shift.
Step 10: Reassemble the printer and retest.
Posted on Oct 01, 2009
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon mp780. Shows an error code of wrong cartridge, even though I have replaced all the cartridges with new canon ones.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Click support tab. Type "error wrong cartridge" - follow directions in results
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm is ringing ##356 is dispayed on screen also on screen is the words check printer press ok
That error is a sheet feeder error, the paper feeder is not moving properly. Any time I've found this problem, I've found broken gear studs and the feeder assembly needs to be replaced. Runs around $40.00 for the part.
Aug 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Jul 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Software for canon pixma mp780
Not knowing where you are from, I can only give the following help.
Do a Google search using the following text:
pixma mp780 +driver
Note the "+driver" (no space between the "+" and the word "driver").
This will bring up a lot of sites where you can dowload the drivers.
Apr 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mp780
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
thats the service manual for your printer it contains detailed step by step instruction in trouble shooting and repair
Sep 07, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
550 people viewed this question
old marine
old marine
