Question about HP PSC 1315 All-In-One InkJet Printer
I need a replacement installation disc - HP PSC 1315 All-In-One InkJet Printer
    President:
  • 1,653 Answers
You can download the application and latest drivers from HP Support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374568&lc=en&cc=us&dlc=en&lang=en&cc=us
Simply select your operating system and then language to see a list of all the downloads.
Posted on Oct 01, 2009
Acer 7530 installation disc
if u bought it new and within two years, you should have a backup disc from your initial setup. if it is an older model u can find it on internet. most times for free.
Jul 03, 2012 | Acer Aspire 7530G Series Laptop...
Tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
on Jan 16, 2010 | Plumbing
What tools needed to replace front brake pads & rotors
Brake Pads
Removal & Installation
Front
3.4L front disc brake assembly
4.0L and 4.7L front disc brake assembly
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Clip, 2 caliper pins, the anti-rattle spring then remove the 2 brake pads
      and the 4 anti-squeal shims
To Install:
CAUTION
Only replace brake pads on 1 side of the
vehicle at a time. Failure to use this procedure could cause the caliper pistons
on the opposite side of the vehicle to pop out requiring the reconditioning or
replacement of the brake caliper.
  1. Remove a small amount of brake fluid from the master cylinder.
  2. Install a used brake pad into the caliper and compress the caliper pistons.
  3. Apply disc brake grease to both sides of the inner anti-squeal shims.
  4. Install or connect the following:
    • Anti-squeal shims to the new brake pads
      NOTE: When replacing worn pads, the anti-squeal shims must be replaced
      together with the pads.
    • 2 brake pads
    • Anti-rattle spring and the 2 caliper pins
    • Clip
    • Front wheel
  5. Depress the brake pedal several times to seat the brake pads.
  6. Check the brake fluid level and top off as needed.
Rear
To Remove:
    this section.
    • Rear wheel
    • 2 cylinder slide pins from rear caliper assembly
    • Caliper assembly from rear caliper mounting
    • 2 brake pads with anti-squeal shims from rear caliper mounting
    • 2 anti-squeal shims from each disc brake pads
    • Pad wear indicator plate from the inner side disc brake pad
    • 4 pad support plates from the rear caliper mounting
To Install:
  1. Install or connect the following:
    • 4 pad support plates on the rear caliper mounting
    • Pad wear indicator plate on the inside brake pad
      Note: Install the pad wear indicator facing downward.
    • Anti-squeal shims on each brake pad
    • 2 disc brake pads with anti-squeal shims to the caliper assembly
  2. Apply lithium soap base glycol grease to the sliding part of 2 caliper slide
    pins.
  3. Install or connect the following:
    • Disc brake caliper assembly with 2 caliper slide pins
    • Torque to 65 ft-lbs (88 Nm)
    • Rear wheel
  4. Depress the brake pedal several times to seat the brake pads.
  5. Check the brake fluid level and top off as needed.
--- Removal & Installation
Front
To Remove:
    this section.
    • Front wheel
    • Front brake caliper assembly
  3. Make matchmarks on the disc and the axle hub.
  4. Remove the front disc.
To Install:
  1. Align matchmarks and disc onto axle hub.
  2. Install or connect the following:
    • Front brake caliper assembly with the 2 bolts
      1. Torque to 90 ft-lbs (123 Nm)
    • Front wheel
Sep 23, 2010 | 2003 Toyota 4Runner
Replaced hard drive acer media recovery disc has 1 of 1 then 1 of 6 have all disc . Have a usb cd rom but it wont install recovery software except 1 of 1 what next
If you never tested the recovery discs, they may be damaged.
You will need afresh install from a windows disc if thats the case
Jun 24, 2010 | Acer Aspire 3690-2196 Notebook
Whem i turn my computer on its says no operating system found.
Unfortunately that means either your windows installation is corrupt and needs to be reinstalled or the hard drive has failed and needs to be replaced. If you do not have a windows xp disc you will need a technician to do this as you will not be able to without the disc. If you do have a disc however follow these steps.
First insert the windows XP disc into the drive
Then when the machine says press any key to boot from CD press enter
Wait for the windows setup to load completely
Then highlight the windows XP partition it should be labeled windows XP
Then hit R on the keyboard
This will start a repair installation of windows
If it does not show the windows xp partition try installing to unpartitioned space
If the windows disc cannot find the hard drive or the repair does not completely unfortunately it means that the hard drive has failed and needs to be replaced.
Feb 26, 2010 | Compaq Presario 5000 PC Desktop
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Need replacement installation disc
Dear Sir:
Do u want operating system disc of drivers disc.
If you want operating system disc.
Please contact the manufacturer of the computer they will be able to send you the disc you need.
if you want drivers disc you can download the drivers for the support site of the computer manufacturer.
Regards
Mohammed.
Regards.
Mohammed.
Jul 18, 2008 | Computers & Internet
Need software install disc
you can get a disk, from the support section. Just look for a link to get a replacement cd.
Jun 24, 2008 | Office Equipment & Supplies
Iriver T30MX Installation disc
I need the drivers for iriver T30MX or the installation disc.
firendly heriberto
Dec 23, 2007 | iRiver T30 MP3 Player
HP PSC 1315 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
