Question about Samsung Digimax 101 Digital Camera
Pictures I have not got a sd card in the camera but have deleated all the pics and it is still saying memory full why is this ?
  • 40 Answers
SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
Posted on Jul 05, 2007
  • 110 Answers
SOURCE: SD Card Wont Work
From the NV3 Manual: (specifications)
External memory(Optional) : MMC/SD card (Up to 1GB Guaranteed)
So the camera may not support a 4GB card.
Try 1GB cards (or smaller).
Posted on Apr 02, 2008
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
Posted on Dec 12, 2008
  • 149 Answers
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Posted on Sep 09, 2009
  • 74 Answers
SOURCE: memory card full but its new!!!!
you may have a bad memory card as well. I had to return one a few months ago it was doing a similar thing. Try formatting it first, you may save yourself a trip.
Posted on Oct 14, 2009
  • 2976 Answers
SOURCE: Full Memory with new cards
Go into the camera setup menu and make sure you have it set to save images on the card, instead of internal storage.
Posted on Dec 19, 2009
0 characters
1 Points
Brand new SD card - says card is full? Nikon D40
Are you sure it is full, did you put it into a computer to check? Maybe the picture resolution is very high or you have videos and there is more than 2Gb worth of photos.
Mar 04, 2014 | Nikon D40x Digital Camera
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
Always says MEMORY Full
Try the SD card on your computer to see if it recognizes and will store pics on the card. If that doesn't help, try another SD card.
Jul 10, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
Erasing pictures
If you erase them off your memory card they shouldn't be transfering back onto your computer. I would say that maybe they are saved on your internal memory of the camera also. Take your memory card out and see if when you turn the camera on you have pics in the camera stored. If you do delete them then. :)
Jan 04, 2008 | Casio Exilim EX-V7 Digital Camera
Digimax L60 will not recognize my card
Your Digimax L60 will also recognize your SD card please select the option to save pics
In camera or in memory card. This time your camera work on its internal memory.
Oct 11, 2007 | Samsung Digimax L60 Digital Camera
I think i deleted all my pictures on the sim card
Before becoming mad: -Take out the memory card from the camera and try it in another camera used this type of memory card. - Try to download your memory card via a memory card reader to a PC or another relevant device (Printer etc) Good luck!
Aug 13, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax 101 Digital Camera Logo
22 people viewed this question
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
