Question about Intel D845GEBV2 Motherboard
Mouse pointer is fixed
I have the mother board D845GEBV2. when i switch on the computer. i get the caution "insert proper boot media into the boot device" and then i give alt+ctrl+del for every tie i switch on the system. recently my mouse stopped working. it displays the mouse pointer but nor the mouse keys neither the pointer does work. what should i do. wher should i check for jumper positions.
    Guru:
  • 597 Answers
Improper boot media means it's not seeing your hard drive. Check hard drive ribbons and power connectors. Your hard drive might have failed if the ribbons and power connectors are installed properly.
Posted on Oct 01, 2009
When i start my computer it works well but after few minuits the mouse strucks but the key board works properly what is the problem?
make sure the lead has a secure seating if applicable or the usb device
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Jun 18, 2011 | Televison & Video
Mouse cursor will not function. Was working earlier today, did re-boot computer 7 times/change battery/etc. Seems to have lost pathway? Keyboard still functions
Check that it still has a good solid connection to the computer. If you are using a optical mouse, make sure the light is on. For a rolling ball, make sure the ball is in the mouse properly and that there is nothing inside to make it stick. Other than that, you may need a new mouse.
Feb 24, 2011 | Computers & Internet
No sound in computer
This board supports AC 97 ADI available at this linl: http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=889&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!,,,,,,sodeep Try clicking the link below
. document.write("Audio: AC 97 ADI*")Audio: AC 97 ADI* (18962KB)
Mar 31, 2009 | Intel D845GEBV2 Motherboard
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Error, sound device can not work properly , plz solve this problem , my motherboard is intel desktop board d101ggc
you can remove the sound driver then re install the sound driver. so you can insert the sound driver cd or mother board cd, then re install the driver .
Mar 10, 2009 | Intel D845GEBV2 Motherboard
G5 Graphics Card Freezes or begins to show lines on display
Since you are able to see your mouse pointer move, the display is refreshing so the problem is with something other than the graphics card. Generally software / OS related.
So assuming you aren't experiencing a hardware failure try the following...
Boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot from the CD
If so run disk utility from the CD and repair the disk as well as permissions. If there are any errors repair again.
If this is successful your computer "should" be repaired. If it is still freezing, use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Cheers
Mar 02, 2009 | Apple iMac G5 Desktop
System not booting
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Feb 03, 2009 | Mercury P4VM800M7 Motherboard
Mouse not working
turn of the computer then plug in the mouse then turn pc back on it should work
if not your mouse may be faulty.
Sep 11, 2008 | Logitech Wheel Mouse Optical
Intel® Desktop Board D845GEBV2.....having problems...can you help?
It could be either your power yuo are supplying is too low or may be your computer is getting too hot.... If it is too hot better if you get a another cooling fan and fix it to the system fan sloty on the mother board, if it is the power supply better if you get a power supply of about 450w or more........
Mar 03, 2008 | Computers & Internet
Intel D845GEBV2 Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
