Question about Refrigerators
Freezer will not cool down to 0 degrees F (48 degrees is the coolest). Fan is working, cooling condenser is clean and it appears the compressor is operating.....
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
I have a GE Monogram ziss48daass 48" side by side that appears to have a compressor problem. With the upper decorative panel removed, the refrigerator cools OK, but he compressor case temp is 219 degrees...
Make sure the condenser fan is working and the condenser coils are clean. The temperatures are very hot but this could be because there is no air flowing through the condenser coils,
Aug 15, 2014 | Refrigerators
Maytag model mtb1956ge
Check that both evaporator and condenser fans are running. Is there any frost buildup on inside back wall of freezer? If so, that would indicate a defrost problem. If all that checks ok, then probably a freon leak or blockage in system.
Oct 03, 2017 | Refrigerators
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Fridge is warm, then cooling again
hi ben.ummmmmm.i dont think so.possibly blocked condensing unit. clean it first.good luck Ali
Jun 25, 2012 | Frigidaire Refrigerators
Freezer cools to 48 degrees
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 01, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
Freezer works fine, refrigerator only cools to 58 degrees on coolest setting!
replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 29, 2009 | Refrigerators
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
