Question about Soyo Computers & Internet
I have a soyo computer monitor, flat, 19
I have a soyo computer monitor, flat, 21". Every half hour or so the screen just goes black. I have to fiddle with the wires in the back, moving them around, to get the screen to come back. It is driving me crazy. What can I do to fix this?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Packldr, If your certain that the monitor is not going into sleep mode, you will need to find out where the possible bad solder joint might be. This type of symptom could be a "intermittant thermal fracture" of a solder joint on an internal printed circuit board inside your monitor. Your monitor works fine until the internal temperature rises enough to cause "thermal expansion" to cause a OPEN connection on some critical component on a "switch-mode-power-supply" or "cold-cathode-fluorescent-tube" power supply circuit. (INVERTER ckt) If you visit youtube, check for videos that deal with "LCD monitor repair" and "bad capacitors", "LCD disassembly" just so you know what you are dealing with. Please let me know if this was helpful to you. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Posted on Oct 01, 2009
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
My Soyo 17" TFT monitor comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after about one second each...
Hi
Thank you for your query
Your monitors inverter has burnt out and will need your monitor replacing
I did not even ask for a bid for this as i dont think you should have to pay for a easy solution
Regards
Shauqat
Sep 24, 2010 | Soyo DYLM24D6 LCD Monitor
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
No screen after 5 minutes
The picture board on your monitor is bad, since it goes off after few minutes and the power led or button is on, it means the picture board of your monitor has developed fault.
I would advice you replace the picture board on the monitor, this should cost you between $65 - $85.
Take care.
Jul 06, 2010 | Soyo DYLM2286 Monitor
My soyo monitor goes off 3sec after i start it i push power button then it comes on then off. steve
..Try to isolated first your connection from your cpu..If cant.visit this site..www.steer-steertech.blogspot.com
Jun 28, 2010 | Soyo 19" LCD Flat Panel Monitor
My monitor goes half red pin striped and black w/ some visibility
It sounds like you may have connections problem (loose or dirty contacts) between the LCD panel and the logic board, look for that first, worst case will the LCD controller (T-CON) board, which is part of the LCD screen panel assembly. See some pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My monitor goes to black. i power off and on and
Your problems describe a bad Power Inverter. It's a small circuit bard inside the monitor, it powers the CCFL lamp of your monitor. Could be cheap to replace, but in most cases you just buy a new one. It could also be a bad CCFL lamp.
Mar 14, 2010 | HP Compaq FP 7317 17" Flat Panel LCD...
I have a thin black line across my screen half way down
You don't say whether it is a LCD monitor or a CRT one.
CRT Trinitron tubes have two thin black lines, one at about 1/3 height, one at about 2/3. This is normal and nothing to be worried about (sometimes one and more rarely both lines can't be seen).
LCD monitors should NOT have any black lines at all, and if they do it's probably a driver latch circuit gone bad -- and there's not much that can be done in practice, except replace the monitor.
Oct 24, 2009 | Soyo Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
119 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
