Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 All-In-One... Problem
Have a cartridge error with a HP 5610 all-in-one. Says to refer to device documentation. Nothing seems to work in fixing the problem. Please help.
  • 27 more comments
  • Penzi Dec 24, 2007
    Says to refer to device documentation. Turned on and of, replaced cartridges. Nothing seems to work in fixing the problem. Please help.
  • AnnandBailey Jan 23, 2008
    I have the same problem... I know it began when another user pulled jammed paper out of the front instead of using the rear clean-out door. I just tried the unplug/replug while pressing the # and 3. It didn't work. Any other ideas to try?
    Oh, and mine is also making a loud clicking noise when the ink cartridges move across, a function that is normally a quiet rolling noise w/no clicking.
  • Anonymous Jan 25, 2008
    vista windows system hp officejet prints blank pages or old documents Keep vista files up to date, change ink cartiges, trouble shoot with internet, willl not print correct page from word...Iget blank pages or test prints
  • Anonymous Apr 24, 2008
    Receiving error message that we have a cartridge error, nothing seems to work, cannot find manual to machine..HELP
    my all-in-one keep saying no answer every time i fax
  • rosie1209 Apr 28, 2008
    My machine says cartridge error refer to documentation. No documentation found on this problem.
  • melissa001 May 06, 2008
    Incorrect Print Cartridge(s)
    The following print cartridge is not intended for use in this printer
    Cartridge on Right
    Refer to printer documentation.
    My printer is an HP Officeet 5610 All-In-One. The cartridge is a HP27 which evidently also goes by the name of C8727A. I actually believed the message and went to the store to pick out the "correct" cartridge. I came home and found out now I have two HP27 cartridges and neither will make my printer happy.
    1)The first thing i did was to go to the hp website and download the drivers in case mine was out of date. I see that now i have the hp solution center software downloaded and it went through the process of installing my printer.
    2) When that didn't solve it I accepted all of Vista's patches/upgrades.
    Now when i go to my device drivers, the device manager says this about my printer:
    Device type: IEEE 1284.4 compatible printer
    Manufacturer: Microsoft
    On the driver tab, it says
    Driver Provider: Microsoft
    Driver Date: 6/21/2006.
    Driver Version: 6.0.6000.16386
    I would have exptected to find that it was manufactured by HP.
    3) I have been looking through the advice for solving problems. I have held the # and 3 down , unplugged it, waited 20 seconds, replugged it. kept holding those buttons down until i saw the reset message. The result was no change at all.
    4) I saw another solution and tried it out. I disconnected the usb and kept it disconnected for the following process. unplugged it, waited 20-30 seconds, plugged the power back in, repeated the unplug/replug 2 more times. The result was no change at all.
    5) Just below the unplug/replug advice I saw another one on a different kind of reset so i did that. held # and 6 down, unplugged, waited 20 seconds, replugged, waited for the NVM reset or whatever message. No change. It really hates the cartridge.
    6) I have called the hp support line and they want something like $34 or $36 to fix this problem. They said they'd download a software solution to my machine. I asked him if I could just download this software myself and install it. He said no. My experience with techs is getting pat on the head and being told there is no problem at all, but they still empty my wallet. I'm hoping you can find an answer for my problem. It will use the color cartridge instead of black ink, so I guess I can just use the expensive color cartridges instead and give up on the whole black cartridge. The downside is that the color cartridge gets empty so fast when youdo that.
  • Anonymous Jun 05, 2008
    that "check the manual" stuff is BS. Let me give you a tip. Nothing is ever found in the manual when there's a problem, that's why I throw them out. There is a hardware problem and that's why it senses the problem with the cartridge.
  • lanky68 Jun 12, 2008
    cartriidge error refer to device documention to troubleshoot
  • Anonymous Jul 15, 2008
  • Anonymous Aug 01, 2008
  • rmehandr Aug 08, 2008
    I had similar problem with my J5780 printer. I was unable to use a refilled color cartridge. Printer kept giving Cartridge Errors, Replace Left Cartridge. I spent a over a day trying to figure out how to bypass this. Tried a lot of solutions given on the web for various HP printers and none of them worked. I assumed that I will ruin the printer or fix it. So I disconnected power at plug and opened the side door (on the left bottom corner). Need to lift a tab on the bottom and pry it out with a screw driver. Now you will see three ribbon cables. Gently remove the middle ribbon out of the white socket. Now, you will see the battery on the board. Mine was welded to two posts. I decided to cut one of the posts. Reconnected the ribbon in the socket. Tried to restart - same problem. Left the power cord disconnected overnight and tried again in the morning. This time I pressed # and 3 together while connecting the power. Kept # and 3 pressed almost a minute. The printer goes thru reset. Follow the display and hit "ok" as needed. IT FINALLY WORKED. So my battery is disconnected - hopefully I will not lose too much of the functionality other than memory of Fax number Redial etc. - which I don't do very often anyway. Now I can refill the cartridges and install them. Hope it helps.
  • rmehandr Aug 09, 2008
    Well, I thought I have found a solution - see my earlier post. Not true. Same problem came back again this morning. So I removed the color cartridge and now will print everything in Black ink - using Gray Scale.
  • medmetal Oct 13, 2008
    just the same...cartridge problem and couldn't solve by resetting
  • Anonymous Nov 29, 2008
    my hp 5610 all-in-one says cartridge error refer to device documentation; what do i do?
  • Anonymous Dec 08, 2008
    it says cartridge error
    can't receive faxes
    5610v won't answer
  • swella Dec 12, 2008
    printer is stating that i have a cartridge error refer to device document i no longer have manual to printer
  • zheng438 Jan 01, 2009
    Cartridge Error message shows up on the panel. Persist after cleaning.
  • nznd Jan 14, 2009
    on HP office-jet 5610.
    I try a replacment color cartrigate - the same type 22.
    First i try an orginal HP 22 from my other HP printer (diffrent model)
    I have this message "cartriage on left not intended for this printer"
    then i try with a new replcment cartrigate .
    again i get the same message.
    Tried reset OK+Cancel. #+6 -- does not help
  • wmgates Jan 14, 2009
    Ink cartridges will not align. There is no paper jam. They seem to be stuck and will not move to the left . It's as if they are stuck. I have checked for any packaging blockage, All I did was replace the ink cartridges as before.
  • Anonymous Jan 22, 2009
    i tried resetting it and it still doesnt work !
  • marcel kouwe Jan 30, 2009
    cartridgefout?
  • lorribell Feb 01, 2009
    HP Officejet 5610 All-in-One prints all but Word. I need this function. What
    next??
  • xaval Feb 10, 2009
    yo tengo un problema me dice error de cartucho porque mi primo ha sacado los cartuchos i al devolverlos los a puesto al reves en el sitio de color a puesto el negro y en el de negro el de color
    pero el problema que tengo es que no hay manera de sacar los cartuchos haber si alguien me puede ayudar gracias
  • Anonymous Feb 21, 2009
    cartridges on right is not intended for this printer
  • Viraaj Singhaniya Jul 02, 2013
    my all the drivers of my printer officejet 5610 is installed in my pc but when i scan some document it shows error of CHECK SCANNER CONNECTION AND SCANNER SOFTWARE so plz help me for this
HI
My HP5610 was acting up with the error in cartridge thiny.
I held down the # and the 3 and reset the unit and it is back
in business.
I love these helpful sites! :)
Posted on Jul 15, 2008
    Problem Solver:
  • 14 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
349
Posted on Mar 19, 2009
  • Dc777 Nov 28, 2010
    This did not work.
    What should I do next?
  • 16 Answers
Is there any other error messages? Like carriage jam or something? If there are no other error then try to do a partial reset on your printer, to do that follow these steps:
Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE.
If this does not resolved your issue I'll try to find some solutions from you.
Posted on Jan 05, 2008
Hi all,
I also had the same problem.
So I bought another HP printer.
But before throwing away the (supposed broken) HP5610 I made the last attempt: I gave it the power with the new power supply and...surprise, the printer worked perfectly!!
I hope this helps, most of all I hope you didn't throw away your HP5610...;-)
Posted on Nov 20, 2008
  • 3 Answers
I bought the Office Depot brand of cartridges. I noticed when the printer went through the cartridge alignment procedure it always showed an error but it would print. When I put in the second EL CHEAPO Office Depot cartridge it quit printing. I went down to Office Depot and told them about my problem and their computer tech said buy genuine HP cartridges. I DID AND IT WORKS. My suggestion is don't use the off brand cartridges. I know that sucks but it cured my problem. I know it will cost more to print from now on.
Posted on Jul 31, 2010
My HP Officejet 5600 series is giving me the Cartridge Error: Refer to Documentation for Troubleshooting , I tried the solution below but it still didn't work and I continue to get the same error, any idea what next to try? Thanks
"Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE."
Posted on Nov 02, 2008
Had printer cartridge error. Did all resets above with no luck. Pulled out both cartridges, then put in black one on right, and then color one. Replaced both and it was color cartridge that was giving me the error. I don't think I have used color one in over a year.
NOW it won't align properly after installing new cartridge. UGH
Posted on Jul 28, 2008
Throw away the printer . It is NOT going to work. I am going to HP Cupertino head quarter to dump it in from of office. They will take it from there .
Happy New Year !
Posted on Dec 31, 2007
Cannot send a fax from automatic document feeder
Posted on Dec 26, 2007
    Scholar:
  • 91 Answers
Here is a great YouTube video that shows you how to change/reset/remove the battery.
http://www.youtube.com/watch?v=zVR2dHebmTI
Let me know if you succeed at this. Thank you, Binary Bob
Posted on Nov 30, 2008
My printer prints a whole bunch of blank papers BEFORE printing the document. What can be the problem of this?? Please help, it driving my crazy!!
Posted on May 02, 2008
SOURCE: cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
Posted on Jun 28, 2009
  • 44 Answers
SOURCE: hi my hp 5610 officejet says
I had this once and it turned out to be a stray piece of tape on one of the contact points on one of the cartridges.
My suggestion would be to get a strong flashlight and inspect both the back of the cartridge(s) and the printers cartridge location slot (copper contact points) where the cartridge gets inserted.
Also get some high quality alcohol and Q-tips and, with the power off, clean both the cartridge contacts and the printers cartridge holder contacts. Let both dry before powering up.
Other than that, I suppose it could be a bad or incorrect cartridge type or perhaps even something in the printer.
Hope this helps... good luck!
Posted on Aug 20, 2009
SOURCE: officejet 5610 fax machine
my printer hp 5610 all in 0ne.
cartridge error reffer to device documentation plz ans.
Posted on Jun 10, 2010
  • 1751 Answers
SOURCE: As i turn on my hp Officejet 5610 an error appears
chang cartridge propably black one
Posted on Oct 30, 2010
puertobori
  • 7733 Answers
SOURCE: HP Officejet 5610 give me cartridge error &
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
Posted on Nov 10, 2010
Help! I keep getting "Cartridge Error--refer to device documentation to troubleshoot" with my HP 5610 series printer. Can't find any "device documentation" to work with. Tried turning printer off, then...
hi
you need to replace one or both of your cartridges with new ones
if you have the old you can check , what cartridge couse the error and you can refill the old one like this
Oct 06, 2010 | HP Officejet 5610 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Cartridge error
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
djiu9ofdfd9
May 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Officejet 5610 fax machine
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
8,679 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
