Question about Dell Inspiron 1000 Notebook
When I plug any USB stick into the port, it isn't recognised. In Device Manager, Other Devices shows yellow question mark against the stick name.
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
Posted on Oct 01, 2009
  • 27 Answers
Try confirming your usb drivers..
Also run a scan against the folders that has your driver files..
That might work
When i plug in my tevion video capture device to the usb port it makes the recognise sound, but im unable to capture video. Whats up???
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps
Aug 13, 2011 | Computers & Internet
My USB drive isn't showing the data that i put on it. The data is still there, but i can't access it
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 11, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My SanDisk flashh drive used to work, now it isn't lighting up when I plug it in the computer and I can't get the files I have saved on it.
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also you can make sure all devices are working
hope this helps
Jul 29, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My edrive isn't being recognised by my computer.
if your e drive is a usb drive
hope this helps
Jul 02, 2011 | Dell Computers & Internet
Hi, i am currently am in posession of a hp tx2508ca tablet, and my built-in hp webcam isn't working. I have also noticed that i have an unknown device in my device manager under usb devices that says...
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
May 25, 2011 | Computers & Internet
Cruzer 8GB usb stick plugged into computer orange light comes on and stays on nothing showing for device in my computer or in disk management and also the same on other computers. many thanks
hope this helps
May 15, 2011 | SanDisk 1GB Cruzer Titanium USB Flash...
Usb ports not recognised
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Regards.
Jun 29, 2010 | Gigabyte GA-G41M-ES2L Motherboard
All of a sudden one day, non of the 3 USB ports on my Toshiba #A135-S2276 notebook works anymore. When I plug in a memory stick or a printer, It will show error message as "One of the USB devices...
Try disconnecting all external devices and reboot your laptop.
You must have all USB devices disconnected, memory stick, USB mouse or keyboard, Hard drives, flash cards ect.
After a reboot check your device manager for flags or exclamation marks and remove if present.
Again, re-boot your laptop and check your device manager.
Ounce you have cleared all marks from device manager and all is clear,
plugin your first USB device and check operation.
Please check your equipment manual for details on what USB ports and speeds are available for your required devices.
Hope this works for you.
Please rate ASAP
Thanks
Dec 31, 2009 | Office Equipment & Supplies
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
USB PORTS
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
Dell Inspiron 1000 Notebook Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
