Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Ionic breeze, red over ride light will not go out
Have cleaned the plates, run the beads up and down on the internal wires, blown the encasement out with compressed air, and the red override light stays on. There's still grime I can not get too in the base, is there anyway to get into the darned thing to clean it properly? have got alergies so would like to be able to use it again, have 2 of these units and have the same problem with both.
Thanks
    President:
  • 1,489 Answers
The internal high-voltage grid wires are connected to a switch which is maintained in the closed position by the tension on the wire.
This red light comes on when the tension in the high-voltage grid wires relaxes or one of the wires breaks thus opening the switch.
There is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended.
Like you I went through the hard-core cleaning pocess, but found it usually makes no difference or very little.
You could try E-Bay for a replacement or shop for a more rugged ozone-generating air purifier -- I'm looking for one myself.
Charlie
Posted on Oct 01, 2009
I have a Sharper Image Ionic Breeze GP S1730 the inside wire broke on. Does anyone know how to repair it????
One person used piano wire, but the diameter must be right so the cleaning beads can slide up and down on the wire when the unit is turned up and down.
Oct 22, 2013 | Sharper Image Ionic Breeze GP SI730 Air...
No air flow in my ionic breeze model S1853. Just the light is on.
The Ionic Breeze filters air from the room into the front vents and releases ozone through the back vents back into the air. Some models you can put your hand near the back of the machine and feel a slight breeze. If you do not feel any air or the light that is on is red, the magnetic plates that capture the dust, etc. needs to be cleaned. Don't forget to turn the entire unit, after removing the magnetic plates, upside down to clear anything trapped near the bottom.
Apr 10, 2010 | Sharper Image Professional Plus Ionic...
Our ionic breeze doesn't want to light up down in side the machine what could be wrong?
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Mar 08, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze Red cleaning light on after a few minutes of running
There's a link to the manual here:
http://www.amazon.com/Sharper-Image-Breeze%C2%AE-Purifier-SI637BLK/dp/B0000AUTU3
Oct 04, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Quadra will not turn on after cleaning
If, when you push the on button it sizzles for a sec and then shuts off (red clean light goes on), I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
Jun 07, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Quadra - only red light goes on.
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
My ionic breeze turbo makesa sizzle sound all the time...its even worse after i clean it. i use compressed air to clean it very well to
Turn the ionic breeze off, unplug it, and turn it upside down. The wires on the bottom of the unit collect dust. There are beads on the wires to scrape that dust off. Turn the unit upside down, and then right side up gently 7 or 8 times and the noise should go away. Yu may need to do this once or twice a week and after cleaning the blades.
May 10, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
177 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
