Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
F 07 fault on my aquarius washer/dryer - Hotpoint Aquarius WD63 Front Load Washer/Dryer
  • 1,029 Answers
This is fault F07 - heater relay stuck. The most common problem for this is the pressure switch sticking. - unplug appliance from mains, remove top, disconnect pressure switch hose from switch, tap switch on tor weight a few times, refit hose, reassemble and test. If this does not work check wiring to heater and meter.
If your fault is heater relay cannot be activated then it's most likely the main pcb that's faulty.
You can check the connections at the heater, they have been known to break internally at the connectors. Also check the plug at the main pcb.
Be careful when working on these machines as the some of the pcb's can hold a charge for a long time
The components which cause this error can be any of the following, heater, ntc, module and pressure switch.
Posted on Oct 01, 2009
  • 3,230 Answers
Well F 07 error indicates that there is some problem in Heater relay seems stuck unplug washer/dryer from mains, remove top, disconnect pressure switch hose from switch, tap switch on tor weight a few times, refit hose, reassemble and test. If this does not work check wiring to heater and meter...... if further you have the same problem then you need to change the heater or, and the power board.
Good Luck!!
Thanks
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code F-07 on the display
Error code F07 indicates the heater relay is stuck, this is not recommended as a D.I.Y repair, my advice would be to call an experienced engineer to look at it, as there may be other probs that have caused this to happen.
Plz rate my soution
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT960 Fault F-07 heater relay
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
Nov 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
459 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
