Question about Samsung Video Cameras
Wen i insert camcoder never digital channel
Wen i insert camcoder any digital channel received. message appear: canale non trovato (italian). Without camcoder all ok.
Not yet resolved
Posted on Oct 02, 2009
Humax code for one for all remote
0382,0381,0724 are the codes to check. For more codes check this.
May 22, 2013 | One For All Televison & Video
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
Feb 08, 2011 | Toshiba XDE500 Player
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
I own a SK-32H240S westinghouse - I am trying to find the channel to where a valid signal can be found - In these channels I surf, all i get tis the "no channel" message - I have DISH NETWORK and am trying...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Check whattype of cable is used to connect the TV to the receiver. If you are using a CoaxCable to connect the receiver to TV1, check the receiver's back panel forthe output name. If your receiver has a "TV CH 3/4 Out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, back if it islabeled "Home Distribution" (ViP Receiver): Tune TV to channel62 or 75. If using non-Coax (RCA, Component, or HDMI) toconnect receiver to TV1, cycle through the inputs until picture appears; MostTVs have a "TV/Video", "Input", or "Source" button.We want to ensure that the TV and the receiver are connected properly, pleasevisit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jul 04, 2010 | Westinghouse SK-32H240S Television
My HD PVR 101-ST has an error code: Er09 when i press th ''ok'' button it shows Er01 when i press ''ok'' it shows 00-- and after a while it shows ER09 again. If i pull the power cord it starts the same...
Hi, just got the same problem.
In my case it started not working well 4 days ago. Today I got a message on the screen asking whether I wanted to upgrade the software. I did and now I have this problem.
In my case I would say that canal digital customer service is quite bad
Apr 25, 2010 | Televison & Video
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Unale to transfer data thru USB cable
was using my DCR TRV 285E model Sony camcoder without any trouble. After a long when i tried to connect the same to my laptop i got message you required ieee1739 port. what can i do for this?
Sep 13, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Denon AVR-3802 Receiver
Video Cameras Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
