Question about Cameras
Can't clear a 13.20.00 JAM IN TRAY 2 error
Can't clear a 13.20.00 JAM IN TRAY 2 error message
SOURCE: error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
  • 14 Answers
SOURCE: Error 13.20.00
There is a paper feed sensor located behind Tray 1 where the tension spring gets knocked loose, therefore the sensor arm is still blocking the sensor. You have to remove all covers and the Tray 1 Assembly and re-install the spring which goes into a slot on the plastic frame.
Posted on Apr 11, 2008
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
  • 214 Answers
SOURCE: Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
Posted on May 04, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For message 3.0 PAPER JAM [LOCATION]
means
Soln
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
241.10 paper jam- couldn't find any paper jam. How do I clear the message?
Error Code: 241.10
Page was not properly picked from tray 1
Possible Causes
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Solutions
1. Fan media.
2. Turn media over.
3. Reduce amount of media loaded in tray 1
4. Replace pick tires.
Oct 29, 2009 | Lexmark T640 Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Cameras Logo
112 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
