Question about HP Officejet 5510 All-In-One Thermal Printer
Paper jam The display screen says paperjam but there is no paper inserted
That is the problem the is no paper particals
Posted on Dec 21, 2007
    President:
  • HP Master
  • 2,022 Answers
May be there is small paper particals in the feeder just open the cover and see there is paper part inside.just remove it and resatr the printer.
bye
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Error paper jam
It is possible that there is a little peice of paper that has ripped off of the sheet that was jammed. Was the sheet whole when you removed it? If not, check the location where the paper was jammed for bits of the last sheet of paper.
Sep 17, 2013 | HiTi P510L Photo Printer
Hp laserjet 3015 paperjam
Plz see if the corner of the paper will be folded or it has been folded earlier and now it is straight then also that paper will be jammed. So use new unfoiled paper.
While inserting it see it is straight in the tray.
Oct 26, 2012 | HP LaserJet 3015 All-In-One Printer
I had a paperjam. I successfully removed the jammed paper, but now the screen still says that I have a paperjam and won't allow me to use my printer
If you haven't already try removing the power cord from the back and wait 10-15 seconds and that will allow it to reset. Let me know what happens!
Jun 10, 2011 | Office Equipment & Supplies
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Jan 15, 2010 | Epson Office Equipment & Supplies
Printer epson r230 paperjam
Indikator paper jam di status monitor bisa berarti benar-benar paper jam atau carriage problem. Coba dibongkar dulu printernya, mungkin ada sesuatu yang nyangkut pada paper feeder, bersihkan sekalian paper sensor pada paper feeder. Kemungkinan kedua adalah problem pada carriage atau bisa jadi pada chip di ink tank. Coba dulu ganti chip pada ink tank dengan yang lain ( yang baru atau yang arc). Salam dari Arema
Dec 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
THERE IS NO PAPER JAMMING BUT KEEPS ON DISPLAYING PAPERJAM
open the cassettes. open and close the copier doors. does the jam clear? if so make sure the paper in the cassettes matches what the displays says. tray 1 8 1/2x11 needs to be the same as what is in the cassette. if this is not he problem then you have a part filure, tire, belt, clutch. you may need a tech.
Oct 23, 2009 | Canon CLC 1140 Copier
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
