Question about Electrolux EOB5665G Ultrafan Electric Single Oven
Only one light comes on, nothing works
Same thing, kept turning off then after 1/2 or an hour it would all start working again, we thought it was a timer problem (grandchildren!!) but now only the left light comes on, grill,fan etc. everything else is completely dead. no internal light, grill, fan, oven, all dead.
any ideas?
thanks pete
  • Electrolux Master
  • 3,361 Answers
Your problem is related to incoming power or range internal wiring.
Verify 220 volts to the range. Pay attention to the wire connections being tight especially the neutral wire.
Posted on Oct 01, 2009
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
We are having trouble with our Double Rack Oven, DRO2G gas. We have lost the rotation. The belt is fine. The telay kicks in when we push the start button but nothing turns. We did get some turning when...
Dave Olivia's Croutons
1 check to see if the fan on the back of the rotation motor is turining
if no then motor / fuses / contacts in the relay may be gone
2- is the shaft turning on the pulley side ( but not turning the pulley) if yes then key has come out of drive shaft
3- if the motor fan is turning and the shaft with the pulley on it is not then the gear (probably the bronze spur gear) is damaged
good luck
Keith
Aug 25, 2009 | Hobart Ovens
Middleby Marshall PS360 pizza oven won't maintain HEAT
sounds like the control cabinet overheated and the controller starts to break down at 140' F I would replace the controller and keep the cooling fans clean
Aug 06, 2009 | Ovens
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
I turned on the main switch,but nothing works
main fuse is on the front panel with the blower fuse
Feb 07, 2009 | Lincoln Conveyor Oven - 1133-000-A
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Cant remove oven light cover
Try a adjustable car oil filter wrench (cost a couple of bucks at Wal-Mart). Simply put it around the glass cover and give it a twist. Worked great for me.
Nov 12, 2008 | Ovens
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Electrolux EOB5665G Ultrafan Electric Single Oven Logo
94 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
