Question about Asko W6021 Front Load Washer
Machine is not going into spin cycle - Asko W6021 Front Load Washer
    Genius:
  • Asko Master
  • 1,466 Answers
Make sure water discharging if not clean filter and pump if need be,,
Posted on Oct 01, 2009
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Model #26842691, Stock # 26842. It will go through the wash cycle, but it will not drain to go to the spin cycle or rinse cycle. It won't forward on. It just sits their.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 16, 2011 | Kenmore Washing Machines
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Machine will not go into spin cycle. It tries but
all the water has to be out of tub before it will go to spin cycle, check drain hose for kink, or belt to see if it is loose
Aug 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Asko W6021 Front Load Washer Logo
80 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
