Question about AT&T Sony Ericsson W580i Cell Phone - White
Cannot enable read user data & write user data in applications
Nokia s40 nokia 2700
firstly install these applications from Nokia store....third party s/w might not work properly. install application with mmc inserted and use them with mmc inserted............Permissions like always allowed/ask first time are only for network (GPRS) access....Mobyexplorer requires net.........many free applications also require net access as they carry some ads....if these permissions are denied then application closes......but be sure....if u select always allow/ allow first time, data usage charges will be applicable
Mar 13, 2014 | Nokia 2700 Classic
Tip
How To Install The LogMeIn Plugin In Google Chrome
LogMeIn is not officially supported within Google Chrome, but the Mozilla Firefox version of the plugin has been verified to work in Google Chrome with the help of the following script: <a href="http://userscripts.org/scripts/show/53796">http://userscripts.org/scripts/show/53796</a><br /> <br /> For XP put script in:<br /> "C:\Documents and Settings\YOURUSERNAME\Local Settings\Application Data\Google\Chrome\User Data\Default\User Scripts" <br /> <br /> For Vista and 7 put script in:<br /> "C:\Users\YOURUSERNAME\AppData\Local\Google\Chrome\User Data\Default\User Scripts" <br /> <br /> To use, you must run your browser's exe with the parameter --enable-user-scripts<br /> <ol> <li>Right-Click on the Google Chrome Shortcut.</li> <li>In the Shortcut Tab, change the Target to "C:\Users\YOURUSERNAME\AppData\Local\Google\Chrome\Application\chrome.exe --enable-user-scripts"</li></ol> Now the LogMeIn plugin can be installed in Google Chrome from here: <a href="https://secure.logmein.com/connect_mozilla.asp?dothis=install">https://secure.logmein.com/connect_mozilla.asp?dothis=install</a>
on Feb 16, 2011 | LogMeIn Pro2
Quick words on word perfect go away
Go to the "WP13US.WPT" file according to the Operating system you have:
Windows 98 or Windows ME
C:\Windows\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows NT 4
C:\WinNT\Profiles\"username"\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows 2000 or Windows XP
NOTE: In Windows 2000 and Windows XP, the Application Data folder is a hidden folder. See instructions below to enable Windows to view hidden folders or to navigate directly to this folder.
C:\Documents and Settings\"username"\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows Vista
C:\Users\"username"\AppData\Roaming\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Than follow these steps:
1. Rightclick on the template
2. Choose Properties
3. Untick the "Read Only" box
4. Click "Apply" than OK
Sep 20, 2012 | Corel WordPerfect Office X5 Standard...
Google chrome keeps going snap why?
"Aw, Snap!" IssueYou may see the "Aw, Snap!" message if a webpage crashes unexpectedly.
SolutionsIf a webpage crashes unexpectedly, you can simply reload the page. If you're seeing the "Aw, Snap!" message for every page you visit, try the solutions below:
Some anti-virus or firewall applications, such as Symantec Endpoint Protection, can prevent Google Chrome from working properly. Test whether such applications on your computer are causing the error by turning them off temporarily. Then try opening Google Chrome again. If you are able to open the browser, you'll need to create an exception in your anti-virus or firewall settings for Google Chrome. Once you've done so, you can then re-enable the applications.
Conflicting applications that users have reported include the following:
  • Spyware Doctor
  • Comodo firewall
  • McAfee Enterprise
  • McAfee Virus Scan
Try disabling your extensions one by one to see if a particular extension is causing the problem.
  1. Click the wrench icon chrome_toolsmenu.gif on the browser toolbar.
  2. Select Tools.
  3. Select Extensions.
  4. On the Extensions page, click Disable for the extension you'd like to temporarily remove.
Go back to your list of extensions at any time to re-enable disabled extensions. You may need to refresh the page in order to use extensions you've re-enabled.
If the browser continues to display the "Aw, Snap!" message, your user profile may be corrupted.
To create a new user profile, follow these steps:
  1. Exit Chrome.
  2. Find the "Default" folder. It's usually located in the following locations:
    Windows
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
    • Windows Vista and Windows 7: %LOCALAPPDATA%\Google\Chrome\User Data\
    Mac OS X: ~/Library/Application Support/Google/Chrome/Default
    Linux: ~/.config/google-chrome/Default
  3. Rename the folder as "Backup default."
  4. Restart Chrome.
it is taken from support site..
Regards
Aug 18, 2011 | Computers & Internet
My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
May 20, 2011 | Computers & Internet
I have an Outlook .pst issue I need corrected. C-Cleaner does not seem to fix the issue and I cannot open Outlook, how can I fix this .pst problem and can it be done for free?
Well, I have been using Outlook for over a decade and met similar error with my Outlook PST files before but got it solved with this PST Repair Tool, the software extracts & restores those inaccessible Outlook items in a new .pst file and enables complete Outlook data recovery. Hope it helps too with your case. Regards!
Aug 15, 2010 | Microsoft Office Outlook 2007: Windows
How to configure or enable hardware compression in DW065B LTO1 Drive. When trying to take backup in H/w compression mode the tape (100/200 GB Tape) is ejected.
The L&TT support ticket contains drive configuration information such as whether hardware data compression is enabled or not.
Use L&TT to pull the ticket then look in the Drive->Drive Configuration section for details.
Here's an example:
|__ Drive
||__ Data compression : Enabled
||__ Current block size : Not available
||__ Detect WORM tampering : WORM not supported
||__ Reads after WORM tampering : WORM not supported
||__ Media removal (software controlled) : Allowed
If data compression is not enabled then it is likely that it has been turned off by the backup application. Check the options in your application to ensure that software compression (done by the server) is turned off and hardware compression (done by the drive) is turned on.
Data compression can be turned on in the drive by
  • The application ( the application will usually override the drive configuration so configuring the application correctly is of prime importance)
  • Resetting the drive
  • Power cycling the drive
  • Using the L&TT Set Drive Configuration utility (use the options to enable compression -see the L&TT user guide below)
NetBackup usersCaution NetBackup will turn off hardware compression in the drive at the end of each backup, so when you look at it with Library and Tape Tools it will be off. This is actually normal for NetBackup, so please check the configuration of NetBackup to make sure that compression is configured correctly. In this case see 'Measure Compression Ratio' (go back one level) as that will show whether compression has been in operation in the drive.
Click here to download the free L&TT utility (www.hp.com/support/tapetools) - this will also access the L&TT user guide
Use the L&TT FAQ to find out how to pull a ticket.
Click here for the L&TT FAQ. (www.hp.com/support/lttfaq) Look for How do I generate a support ticket? in the contents.
Aug 03, 2010 | HP HEWLETT-PACKARD DW065B ULTRIUM 232...
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
I cannot get any type of folder like application data in my computer/local disk c/documents and settings/ user
Go to My Computer -> Tools -> Folder Options -> View and select "show hidden files and folders" this should enable you to see the application data folder.
Mar 08, 2009 | Microsoft Computers & Internet
AT&T Sony Ericsson W580i Cell Phone - White Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
