Question about Dual Electronics CECT P168 Cellular Phone
KA08 mini won't work on my laptop
KA08 won't work on my laptop when I plug it in via the USB cable .. driving me crazy! Also it says it has 8GB but then when I try to blue tooth something it says it has no memory?!
    Problem Solver:
  • 5 Answers
Thats because the phone isnt 8GB it means it can hold 8GB memory card. You will have to buy a micro SD card then it will work
Posted on Mar 05, 2010
When I connect MP3 player to laptop via USB cable, it does not show up in removeable devices. Laptop does not recognize it. Worked previously. Please help.
is it powerd on? some devices need to be on before the computer can recognize it like my digital camera has to be on before i can use it via the USB cable
Jan 16, 2016 | Eclipse Fit Clip Plus 8GB* MP3 Player
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see http://www.samsung.com/ph/consumer/monitor-peripherals-printer/optical-disc-drive/dvd-rw-drive/SE-S084C/RSPN/index.idx?pagetype=prd_detail
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
8gb flash drive won't work in my old mac lap top, trying to put files backed up from another drive on it
When you plug it in does the mac laptop even register that it has been connected? I'm also assuming the usb drive works on your other computer?
Aug 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
My hp mini 8g is all used up and I do not know why? I only use this to serve the net, no downloading etc... I tried to have the drive defragged but even that does not work? Any solutions?
If you have an HP mini like the 1010nr, you may have only an 8GB solid-state "drive" the solution is to: 1) plug in a usb drive to a side port for extra space; or, 2) BETTER - pull off the cover on the right side to access the hidden USB port and install a permanent large-capacity usb memory module, then replace the cover. This requires a small usb stick with little or no case (like this: http://www.ebay.com/itm/PNY-Attache-Paris-16GB-16G-USB-Flash-Drive-Stick-Purple-/250804063654?pt=US_USB_Flash_Drives&hash=item3a65164da6) -REMOVE THE OUTER CASE FIRST.
Aug 19, 2010 | HP Mini 1010NR Notebook
Manual of Mini Iphone Ka 08
You can download the user manual (CECT KA08) for free from:
http://safemanuals.com/user-guide-instructions-owner-manual/CECT/KA08-_E
Jan 25, 2010 | Cell Phones
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Another firewire problem
there's a cable out in the market , it's a firewire and usb connector. you can use the usb for plug into your laptop and use the firewire to your video camera. Its a bit slow but that would help you.
Jun 22, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Dual Electronics CECT P168 Cellular Phone Logo
152 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
