Question about Haier Dishwashers
We have a Haier dishwasher and the capacitor burned out. The mahcines are sold at Argos and Comet but I can't source a replacment part which seems kind of crazy. It is out of Warranty and comet can't help. The capacitor is 5uv and has 2 pins. There are generic alternatives with 4 pins. Comets spare part place doesn't sell the capacitors separately and don't know if they come as part of a wider unit. Can anyone help I understand these parts cost about £6 and don't want the expense of a new dishwasher just because I can't track one down. Thanks
  • 923 Answers
Make, model, serial number of your unit is ... ? I have dealt with capacitors for over 50 years, so I know what I'm doing. But there is no such thing as a five MICROVOLT capacitor, which is what 5uv means to a scientist like myself! Did you mean five micro FARAD, which should be expressed 5uF? But the voltage rating is critical, and the physical size is critical and the temperature rating is critical and the lead diameter is critical and the lead spacing is critical and the style (axial lead versus radial lead) is critical.
Posted on Apr 20, 2017
SOURCE: I have Kitchen Aid Dishwasher
I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
Posted on May 29, 2008
  • 171 Answers
SOURCE: LG Dishwasher LD 2060SH OE Error code Draining problem
Hi sonicmule,
I'm Harvey the Master Plumber.
Your question is: Re-circulation pump was replaced under warranty after 7 months. Now there appears to be draining problems. hose not kinked and filter seems clear - I guess the pump is either broken or something has jammed it. Does anyone know how to get at it??? Warranty has expired and a new pump + fitting is gonna be expensive. Any tips?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. The unit must be removed to access the pump. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 6784 Answers
SOURCE: LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Posted on Jun 21, 2009
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
SOURCE: Door lock for dishwasher
Hi Sylvia, did u manage to find a supplier ??? as my aunt now has this problem. Please get back to me if u can help, it would be much appreciated !!!!
Posted on Jul 13, 2010
I need a user manual for a HAus HW50-1010 Washing machine
It seems that Argos recycled a brand called Haier (Chinese) and turned it into HAUS (German)!!
The washers are exactly the same. Manual is the same.
Jul 13, 2010 | Washing Machines
Hi there, few days ago my HAIER 12,000 btu, ESA3125 died. it smell like burning wires. after i disconnect it from the wall and after putting my rubber gloves i open the case that holds the circuit and...
You should be able to take the information you have (on the capacitor) to Air Conditioning Supply House and purchase an exact replacement.
As to the diagram. There should be a schematic on the unit - somewhere. Usually located on an 'inside' panel.
Unless someone has removed it - the AC will have a schematic on it.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Does the haier hdw100sct dishwasher have an inbuilt dryer to dry the dishes at the end of cycle? feel like i've been sold a dud
yes it should have it should heat the interior of the unit up, this will dry the dishes. The element is usually at the bottom.
Mar 30, 2010 | Haier 24 in. ESD100 Built-in Dishwasher
Shops cant get them
If you go online to currys or argos and maybe comet you can quickly search a lot of stores for stock and then reserve the game for you to collect. Or if you are desperate / not so bothered about paying over the odds try amazon or
Dec 19, 2008 | Nintendo Professor Layton & the Curious...
Westpoint Dishwasher
I put the mahcine on as normal but it does not go past the first cycle of the red flashing light?
Sep 08, 2008 | Dishwashers
Universal remote control codes
It will work with a Total Control TV Replacement Remote Control, which you can get from argos for £7.99.
There are only 2 codes for a haier tv.
Setup Code : 0698
Setup Code : 0264
Feb 05, 2008 | Haier TN201AUV 20" TV
Pump not draining - Haier portable dishwasher
purchase new pump at
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Haier Stainless Steel dishwasher
If you can hear a humming sounf it will be the pump motor not working. If you can get to the back of the pump try and turn it by hand with the power on. If it then starts it is the motor start capacitor
Oct 07, 2007 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
