Question about Homelite Consumer Products Backpack Blower/Vac, Carb
No spark to plugs affter long storage. Don't have
No spark to plugs affter long storage. Don't have manual for LRI4400 Homelite generator to ensure I have eeverything set correctly.
  • smshirk2 Oct 01, 2009
    I am pulling on the rope, my model does not have electric start. The plug is good, the fuel was drained before storage. Oil has been changed.
  • 10,865 Answers
There will not be any spark to the plugs unless the engine is running, or you are manually pulling on the rope.
Go to any auto parts store and get a can of starter fluid, a new spark plug and a new air filter. Pour out the old fuel and mix up a new batch. While at the store also get a small bottle of homelite 2 cycle oil to mix with the gasoline.
Install the new plug and pour in the new fuel mix. Leave the air filter off and squirt some starter fluid into the air intake as you pull the starter rope. It helps to have this be a two person job.
Posted on Oct 01, 2009
What is a replacement spark plug for the Homelite DJ168F-18500A plug provided with this unit?
HOMELITE DJ168F-18500-A - SPARK PLUG - Part Number ...
www.smallenginesprodealer.com/homelite/.../homelite-dj168f-18500-a-spa...
HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ... This is an original approved HOMELITE replacement part.
A100643 - SPARK PLUG - Part # A100643 - Small Engines ...
www.smallenginesprodealer.com/homelite/.../a100643-spark-plug-part-a...
This is an original approved HOMELITE replacement part. ... HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ...
HOMELITE GM304012 - SPARK PLUG A - Part Number ...
Jan 18, 2016 | Homelite Garden
REPLACED PLUG BUT STILL NO SPARK FROM COIL
The first thing I would do is replace the points and condenser. These parts may be under the fly wheel or just outside it.
Feb 07, 2015 | Homelite Vintage Generator Parts Manual...
I have homelite textorn 7500watt generator not strating ,no carunt to spark plug
You'll need to look up to see what the ohms are on the coil of that chainsaw use of a multimeter required it should have a reading between to set readings if ok then check for loose or broken wires
Feb 07, 2015 | Homelite Garden
Homelite hgn 0960a generator wont start no spark
Change Spark Plug. Check The starting Switch with a Multitester if it have continuity.Start it again and check Spark with the spak plug unplugged and with the crankcase check the spark.
Check the oil level. almost all the new and modern generators have included an oil alert gadget that cut off for saving the engine.check oil level and refill if it need.start it again.
Sep 02, 2014 | Electrical Supplies
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Generator output plugs don`t work
If you don't see a reset then you may have to replace a diode or voltage rectifier inside your unit.
Nov 29, 2013 | Homelite Lr5000t Generators
Hi we have a wolf 950 generator that wont start,cleaned plug,is there anything else i can try,HELP!
are you getting spark. pull out your plug and with the wire connected. hold the plug about an 1/8 of an inch away from any metal on the motor and ensure your getting spark. also check to ensure your fuel is not bad..
Aug 14, 2011 | Wolf Manufacturing Electrical Supplies
Won't start. changed gas. oil is okay. added fuel additive. new spark plug.
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Loosen bolt on float bowl. Fuel should start leaking from around top rim of bowl, if it doesn't then there is a restriction somewhere in fuel line or float valve is blocked in bowl.
Feb 21, 2011 | Coleman Powermate Premium Plus 6250W...
Homelite portable generator, LRIE4400...no out put fr unit..has been discontinued fr a few yrs..no parts available..known fr circuit board failure..my dad's , maby 50hr on unit..how can I bypass..or obtain...
If the engine is running but no output from the plugs....the VERY common problem is loss of magnetism in the generator after storage.
With the generator off.........
Look at the side of the generator part.....do you see a small + and - on any terminals?
You may have to take a cover off.
Take a 9 volt battery and momentarily put current from this small battery through these terminals.
Now.....start her up and check for power at the plugs.
This fixes 75% of "no output" after being "stored" generators.
Sep 09, 2009 | Electrical Supplies
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
227 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
