Water left behind drain plug at end of run
Our Miele plus 6 washingmachine has over 1 litre of water still in the drain plug each time its used. Coin, hair grip and collar straighteners removed but it theris still water behind the drain plug at the end of a run. Is this normal or is there a blockage elsewhere beyond the impeller?
Thanks
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
C ould be elsewhere or damage to pump impeller/ blades..Check pump loose blades....
Posted on Oct 01, 2009
How to open this rinse boiler for tefal pro express 2929 iron
Hello there. Place a coin in the groove running along the centre of the plug and twist it, or lie the end of a screwdriver into the groove and twist it. If the plug still will not move then it is jammed in with scale.
Please see below how I solved the plug problem when it was being held down and was immoveable due to scale.
NOTE: In future always use $2.00 litre bottles of distilled water from supermarkets in your iron, never use scale laden tap water.
Tefal pro express steam generator iron I need to drain '& clean the boiler but the boiler drain plug is seized I can't loosen it
Use a small tack hammer (its head covered with a cloth) they have a far smaller and lighter head than a standard hammer. Tap all around the edge of the plug and in the middle. My thinking is that the plug is in the grip of scale. The tapping loosens it and it falls off. This worked for me.
Also tap the end of a tiny screwdriver like watchmakers use, or the head of a fine tip kitchen skewer around the perimeter edge of the plug, go gently around twice, plus the other tapping and it breaks the seal formed by scale which is holding the plug down.
Next, fill and rinse the boiler out up to 6 times to get rid of all the sediment and the rinse water runs 100% clean. Always use distilled water from supermarket from now on (litre less than $3.00). No more scale, no more cleaning. WARNING: Make sure boiler is totally water free after final rinse- out. Refill water container on the actual iron itself with distilled water from now on.
Please let us all know if this worked for you and if my post was helpful. Good luck with it, Chris.
Feb 04, 2015 | Tefal Irons
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Miele dw flashes 5 times, water is draining. Suspect filter/valve housing at end of water inlet line. Their is a wire running to this valv so I imagine whatever solenoid that tells the valve to open and...
which light is flashing? if the intake drain light is blinking and you dont hear the drain pump, it means water is not coming in. if the drain pump is running all the time, it means water has leaked into the bottom pan. behind the plastic toe kick, there is a panel that can be removed with two phillips head screws. It you can see water in there, you can dry it out, and try to run another cycle. if it runs fine, cut back on your detergent usage. if it leaks again within a cycle or two, you will need to locate the leak and repair.
Nov 18, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Have miele g611sc dishwasher opened up after cycle lots of water and bubbles in bottom ??
Sounds like it is either not draining properly or the type of powder or tablets you are using is sudding up too much and will not drain away the bubbles.
The 611 is a small dishwasher and only requires a small amount of powder.
try running a few cycles with no powder and see if it drains the water away ok. if it does then it is the detergent.
if there is water left in the base at the end of the cycle check the drain hose connection under your sink and make sure there are no blockages on the u bend spigot where the hose connects. if the unit does have a fault like not draning then the inlet/drain light will lit up.
hope this helps
Apr 21, 2010 | Miele 24 in. G646SC Plus Free-Standing...
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
Water left behind in filter reservoir
There is always water left in the filter at the end of the cycle. Tjis is unlikely to cause the smell problem though.
If you do a lot of 40 degree washes and use a biological detergent you can get a bacteria build up in the appliance which is very unpleasant.
To rectify this, run the appliance on a 90 degree wash with two spoonfuls of washing soda in the soap drawer. Allow the program to complete the cycle( no clothes though) and repeat once more.This should help clean the appliance.
Several appliactions may be required if smell persists.
Nov 16, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
