Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
Amp works for a few minutes
Amp light is green when i turn it on after a few minutes it turns red
  • 38 Answers
Too much power. turn your amp down a bit and let er rip.
Posted on Oct 03, 2009
Sony KDF-55E2000 power led blinks red 3 times....
Are you using an extension cable? If you are, try plugging it directly into the wall.
Alternatively, call up the helpline and they may be able to provide more insight into your specific problem.
Jul 20, 2017 | Sony Grand WEGA KDF55E2000 55" Projection...
Still having amp problems
Hello lilmario,
After eliminating wiring problems and possible shorts, grounds and low impedance in the speakers, most likely the amp is failing internally. A partial failure of either the output MOSFET's or the thermistor. In either case, the repair requires removal and replacement of components on the circuit board. Depending of the age and original cost of the amp, such repairs are sometimes expensive.
I'd recommend having a professional audio shop test the amp and provide an estimate for repair.
Hope this helps.
Sep 21, 2009 | Car Audio & Video
Red light comes on for a few seconds
Check the feed fets or the audio amplifier IC´s are damaged
Aug 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
Red Power Protector light
Hi, the only way i can see the amp resets the stereo is that power is dropping. The amp should have its own wires directly to power/battery so as to not affect anything else.
On the protect, try to disconnet all the speakers, make sure the power is OK. If it appears to work, the there could be a problem with speakers/cables. Try a different speaker to see if it works. If the problem continues with speakers off, a different speaker etc, then there is a problem with the amp. Hope that helps
Jul 21, 2009 | Sony XM-2100GTX Car Audio Amplifier
Sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Jun 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Jh202 amp works for a few minutes stops for a few minutes any ideas
Sounds like the amp is going into Protection Mode. Does yours have green LED light then RED LED on it? The green is power and the red is Protection. You will need to either change the OHMS wiring or Put A Fan on it to Keep it Cool Inside.
May 11, 2009 | MTX JackHammer JH202 Car Audio Amplifier
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
you need to get a fan for it because it does not come wit one and when you get the fan you have to hook it up from the inside by taking the torture tested/bolt sign off and look for a small white pug to attach it to
Dec 08, 2006 | Lightning Audio Bolt B2.150.2 Car Audio...
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
149 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
