Question about Nokia 6280 Cellular Phone
No network connection cant make any calls or text
I've tried reflashing with later software the same as on my other phone.
updae good but the phone still hasn't got a connection.
I suspect that something has blown on the RF side of things
  • 97 Answers
Hi!... If the network problem is occurred after reflashing, i suggest you should do the process again. And if the problem already exist before you had it flashed so it might be hardware. Try check the antenna first before going touching the RF parts. If you are not familiar with ESD's, better have it repaired to an Authorize repair center 'coz these parts are very sensitive.
Posted on Oct 01, 2009
My gprs can't connect.what will i do?
Good day. First check if you have load, I mean is your phone can able to call? because its simple reason why the phone cant access the net. Secondly erase and reinstall the configuration settings for gprs, or call your network provider then ask for settings to run your device. I'm sure they will send the settings thru text message, save and set as default to your phone. Once save, press zero and hold till you see the globe icon is turning. Sometimes need a few hours to make a good connection or it depends on your area if you get a strong signal. Thanks
Sep 18, 2011 | Nokia 6300 Cellular Phone
The network operator is displayed on the screen and i also have full network bars. But i cant make or recieve calls ,text or browse on my blackberry 8310. The problem sometimes goes away when i perform...
Try to unlock your blackberry network using blackberry curve 8310 unlock code, see if the problem is still happened after your blackberry network unlocked. If the problem still same, reflash your blackberry phone or you can do cable unlock in nearest local mobile phone repair shop in your country. It will force to reset your blackberry configuration to default.
Jul 04, 2011 | RIM BlackBerry Curve 8310 Smartphone
Please help i cant send text messages from my motorizr z3 but i can still receive text messages, when i try to reply or compose a message it says please try again later....
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 01, 2010 | Cell Phones
Boost sim in i930nextel motorola phone. unable to use messaging
make sure in your internet explorer settings under connections you have automatically detect settings check and on select network you have the internet if this didn't work lets keep trying in settings and phone calls make sure you have phone only set to off now try connecting again and let me know if this help your problem
May 28, 2009 | Motorola Mobility i930 Cellular Phone
PHONE WONT RECEIVE CALLS, UNLOACKED AND SIM IS O2. CALLER GETS CANT CONNECT YOUR CALL MESSGAE. YET TEXTS GO THROUGH FINE
try have the OS reflash on the phone or call the carrier and have them try to rectify the issue for you.
May 17, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Mar 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
W850i not calling or texting
your probably on another network to her, you need to get the phone unlocked to any network. Most 2nd hand mobile shops will do this for you for a bout a £5
Feb 17, 2009 | Computers & Internet
Text problem
Check to see if you have an excessive amount of txt messages stored on your phone. If so, clear/delete messages off the phone. If this doesnt solve the problem, it could be a software problem.If it's under warranty, return the phone for servicing. If it's not under warranty, then reflash the phone with new software.
Dec 07, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Nokia 6630 wont dial out
i too have the sam problem with my nokia 6630 . its not a good cell phone i have to say . the problem u said is generic for all nokia 6630 . when u try to dial from phone book it dosent get called while u try to dial that number from keypad call goes . this is common for 6630 . any way i ahve sold it out thanks god
Dec 05, 2007 | Nokia 6630 Cellular Phone
My motorola v3x problem
have the flexcable replaced and also have the firmware reflashed.
Oct 02, 2007 | Motorola Mobility RAZR V3
Nokia 6280 Cellular Phone Logo
83 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
