Question about HP DeskJet F380 All-In-One Printer
Printer takes one paper and does not print
When i give the command to print, it only takes one paper and runs it through, without printing.
  • guusblok Oct 01, 2009
    i have the latest driver
  • 657 Answers
That is nothing more than a driver issue, simply update the drivers from Device manager and it should work
Posted on Oct 01, 2009
  • Laxman Bisht
    Laxman Bisht Oct 01, 2009
    If you are facing this issue inspite of having the latest driver, I would suggest you to remove all the printers and add the hardware manually from Add Hardware Wizard. That would surely resolve the issue
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
Paper feeds straight through printer without pausing to allow printing
You need to check your print settings in your print menu (it will open when you give the print command i.e. ctrl P) for the "reject inappropriate or wrong sizes." Here you most uncheck the radio button. Click on properties on the print menu and go from tab to tab to see where you see something like "reject inappropriate or wrong sizes." Usually when this radio button is checked the printer will send all wrong paper sizes through without printing.
Feb 04, 2010 | Epson Stylus Photo 1290 InkJet Printer
Can my esp5 all in one printer ,print both sides of a4 paper. if so how do you do it, ? Mak
Mak,the printer does not have the duplexer to print on two sides of paper,you need to manually flip the paper in order to get it to print on both sides.First of all give command and get the print out on a sheet.Place that sheet again the other side facing down on the bottom tray and give print command.You will get two-sided prints.
Dec 14, 2009 | Kodak ESP 5 Printer
Out of paper issue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
this will clear out your print queue without having to restart. Good luck!!
Hi this is the more effective way to refresh the print queue.
Manually Stop and Restart the Spooler Service
1. Click Start, click Run, type command, and then click OK to display the command.com window.
2. Type net stop spooler, then press .
3. Type sc config spooler depend= RPCSS start= Auto, then press . The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
Type net start spooler, then press
NARENDER KUMAR RANA
narendertacl@gmail.com
narendertacl@yahoo.com
narendertacl@hotmail.com
Nov 15, 2009 | Kodak EasyShare Printer Dock Series 3
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Command Work Station Software
xerox fiery x12 command workstation downloads
Sep 15, 2008 | Xerox DocuColor 12 Printer
Paper feed problem
usb port or printer adapter problem.check both of them.wish success
Jun 04, 2008 | HP Deskjet 2360 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
