Lexmark z705 printing blank envelopes soft ware is set right /using Microsoft office word 2007/ Printed the envelopes for a while in black, then in red now everything is blank. Prints everything else ok.
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white." 2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab. 2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer. 2. Get a damp paper towel. 3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 5. Next dab the cartridge on the towel to make sure that the ink is flowing. 6. Snap the cartridge back into the printer. 7. On your computer, select "Old Cartridge installed." 8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz
" - pomerson
After re-installing the operating system on E machine with Vista Home Premium 32-Bit, the Lexmark Z...
(More)
After re-installing the operating system on E machine with Vista Home Premium 32-Bit, the Lexmark Z 705 Printer won't communicate with the PC. I am unable to uninstall the printer program because the printer has an assignment pending. Please help
I live in a block of flats and printing at odd hours is awkward because of the loud programed voice...
(More)
I live in a block of flats and printing at odd hours is awkward because of the loud programed voice that says, "Printing started," and "Printing complete." Can you please tell me how to turn it down or switch it off? I have a Lexmark X5070
Hi, Still having problems downloading the disc for my Lexmark Z705 printer to my Gateway laptop with...
(More)
Hi, Still having problems downloading the disc for my Lexmark Z705 printer to my Gateway laptop with Windows Vista. I have been told by Lexmark to download a driver using someone else's high speed connection....I have dial up....then copy to a disc. I am going to take my laptop and printer and try to download the driver directly to my laptop using a friend's high speed connection. He has a land line, so I can call Lexmark tech support and have them walk me thru it. I think the major problem is that I have dialup. What do you think?
