Question about Toshiba Satellite Pro A200-EZ2204X Notebook
The headphones on my Tosiba Satellite Pro A200 dont work
The headphones dont work when I plug them into the jack point, sound still comes through the main speakers. It used to work fine then one day it just stopped.
I was wondering if this is a hardware issue or is there somewhere I can go to turn it on or off?
  • 329 Answers
It might be hardware technical problem.. i think headphone censor in the port is not working get it repaired from local service centre
Posted on Oct 01, 2009
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I have a Satellite L300 and have a sound problem, sound only comes out of right speaker (despite balance set mid point) and no sound comes out of headphone jack!
I have seen this many times and found bad solder joints on the motherboard on the bottom side of the headphone jack. I have also seen the plug coming from the speakers to the motherboard lose. If you feel this is too much for you to handle then you need to go to a PC shop or a friend that can solder PC boards. Good luck! Phil
P.S. This is not a software issue for certain.
Dec 02, 2009 | Computers & Internet
Bios Pasword
Unfortunately, if you can't remember your bios password you'll have to reset the CMOS. This is usually done via a jumper on your laptops motherboard itself, or removing the battery on the motherboard while the laptop is unplugged and the main battery is taken out. Be very careful when opening up your laptop, make sure all the screws needed are removed, as they are easy to miss. If you don't feel comfortable opening up your laptop, I would recommend taking it to a certified technician.
May 06, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Headphone problem
GO INTO CONTROL PANAL GO TO SOUND OPEN FOLDER GO TO SOUND TAB AND FIND WHAT ITEM YOU ARE HAVINGISSUES WITH HIGHLIGHT IT AND TEST IT TO.
DEVICE MANAGER IN CONTROL PANAL, CHECK THE DEVICE AND IT DRIVER AND ANY NEW UPDATES
Feb 12, 2009 | Toshiba Satellite Pro L300 Notebook
Headphone Jack is NOT working properly
Check your sound device levels. you may need to enable that headphone port before it is usable. you can do this in the control panel tab. reinstalling your sound drivers wouldn't hurt also.
Jan 28, 2009 | Toshiba Satellite A105 Notebook
Problem with speakers, Mac laptop MacBook 13" white
HAHA i had the same problem so here is what i did...i stuck a head phone plug in the jack and smacked it a couple times and bam it works....i would suggest doing this if your lazy otherwise go to the apple store because obviously somthings not right in your laptop.
Aug 23, 2007 | Apple MacBook 13"White /2.0Ghz Intel Core2...
No sound after pluging in headphones
Not unless you know how to work on a headphone jack and how the jack and the jack switchs work??? Also if you dont know about the HI Voltage saftey issues, it would be best for you to bring this set to a pro tech, as it shouldnt cost to much for a new headphone jack??. Good Luck
Aug 04, 2006 | Sylvania 6419TC 19" TV
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
275 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
