Question about Sanyo Vpc-s1070w Digital Camera
Sanyo VPC-T850 power problem?
Camera will power on, lense extends briefly and shuts down immediately retracting lense. I have reset it and tried a new battery, nothing works.
  • 107 Answers
SOURCE: Lens will not retract on Sanyo VPC-T850, 8.1 megapixel, digital
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
Posted on Jun 10, 2009
fotomohamed
  • 321 Answers
SOURCE: Sanyo VPC-T850 shutting down
use NiMH batt.
Posted on Jun 18, 2009
  • 11967 Answers
SOURCE: My camera will not retract its lense and now I can't use it
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 26, 2009
Testimonial: "thank u!!!! this i tried all the methods in order and i finally tried fix#7 and it worked! i think i hav sand in my camera from a vacation"
  • 11967 Answers
SOURCE: my sanyo camera vpc-t850 s/n 08061106261 will
Posted on Dec 01, 2009
SOURCE: my sanyo VPC-T850 turns on,
i have had the same camera doing the same thing sence i took it out of the box, however i have no recipt because it was a gift and sanyo still will not fix it even after they admited it was a manufacurers defect, never buy their products again, i am boycotting sanyo and all they sell! their customer service reps are the most rude and nasty people i have ever encounterd in a call center and that includes the highest up person you can talk to, trust me i talked to him more than once trying to fix this p.o.s camera.
Posted on May 27, 2010
When I Turn On My Sanyo VPC-T850 Camera. It turns on and then it shuts off immediately. how can i restart it?
Did you recently drop it? If so, it's a lens error which is expensive to fix.
Jul 01, 2011 | Cameras
I have a sanyo vpc-e890 and its less than a year old now it wont power on and the lens is stuck out
The systems control board has detected a problem with the camera lens and shut it down. The lens is run by a tiny motor that extends and retracts for focusing, the motor has seized or the gears have jammed preventing operation. The only option is to take it to a camera technician to see if he can salvage the lens, or replace it.
Jan 14, 2011 | Sanyo Vpc-s1070w Digital Camera
I turn on the power, the lens extends briefly and shuts down immediately
Hello :
Maybe you need to replace the battery or clean the battery base . Maybe it became rusty or there's isolation stuff on it .
good luck .
please don't forget to rate !
Apr 04, 2010 | Sanyo Vpc-s1070w Digital Camera
Error lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 20, 2009 | Sanyo Vpc-s1070w Digital Camera
Camera turns off sanyo t850
The problem that you described is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 11, 2009 | Olympus Camedia C-765 Digital Camera
Good Luck!!!!
Jun 10, 2009 | Sanyo VPC-S880 Digital Camera
Sanyo vpc-503
well if lense stuck in your neighborhood there should be a camera store you should take it in and have your cam. serviced for a clean
the other thing could be memmory card is full
or the camera is on but just not like the light or focus check all above
hope this helped
May 07, 2008 | Sanyo VPC-S500 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
166 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
