Question about Karcher Garden
Powercraft pressure washer cuts out soon after startup and wont start up again
  • paulinegribb Apr 10, 2010
    hi water is coming out from under the washer
4 Suggested Answers
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 68 Answers
SOURCE: karcher 432m pressure washer cuts out after 3
Could be your motor overloading. I would first try a new motor capacitor.
Posted on Jun 10, 2010
  • 13 Answers
SOURCE: My Powercraft 9686 pressure washer
put some silicon spray in inlet/outlet then reattach hoses then run it will proform after a while do this everytime you store it pryer to sroring away...........
Posted on Jan 19, 2011
Why did my powercraft 1619 will not go again after I stopped for a moment mid-cut?
perhaps the blade is in a bind . remove from wood and try
Jun 26, 2014 | Saws
Wont restart
high pressure cut out switch faulty. dismantle unit dismantle and clean or adjust r replce micro switch ( on pump head )
Apr 19, 2014 | Task Force 2000 PSI Electric Pressure...
My Powercraft 9686 pressure washer has always been stored in my garden shed. It is 4 years old and when I used it last September the power washer had lost considerable pressure, as it was leaking water....
Jan 17, 2011 | Craftsman 2700 PSI Briggs Stratton...
Pressure starts and stops
Sounds like your unloader valve is sticking. It needs to be removed and lubed with lithium grease.
Jul 08, 2010 | Karcher 2500 PSI Pressure Washer
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Mar 16, 2010 | Northstar Pressure Washer 3000 PSI
Pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Dec 08, 2009 | Garden
I have a PW1686 power washer but it runs for a few minutes then cuts off. After a few minutes it starts again then goes through the cycle of on and off. Kindly tell me what are the possible causes.
The problem sounds internal (perhaps the temperature cut-off switch or the auto-start-stop switch). For safety and possibly warranty reasons, you should not open the case to investigate or repair; take the unit to your local service center.
Oct 08, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Garden Logo
773 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
