Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
Foil Method 2(3x-4)(4x+5) - The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
  • The Learning... Master
  • 7,993 Answers
You have the method: apply it.
2 *(3x-4)(4x+5) =(6x-8)(4x+5)
Now apply the FOIL method
F: 6x*4x=24x^2
O: 6x*5=30x
I; -8*4x=-32x
L: -8*5=-40
so the result is
24x^2 + 30x-32x -40 =24x^2 -2x-40
Posted on Oct 01, 2009
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Demonstrate how to multiply two binomials
Try to seek these: By using the suggested format:
Suggested su
  1. Adding and Subtracting Binomials
    • 1
      Arrange each term in each binomial in order of degree from greatest to least. The degree of a binomial is the exponent attached to the term. For example, 4x^2 is a second degree term.
    • 2
      Multiply each term in the binomial that is being subtracted by -1 to turn it into an addition problem. For example, the problem (8x^2 + 8) - (x^2 - 2) becomes (8x^2 + 8) + (-x^2 + 2).
    • 3
      Combine like terms. In the example problem, the x^2 terms are combined and the constant terms are combined, yielding (8x^2 + 8) + (-x^2 + 2) = 7x^2 + 10.
    Multiplying Binomials
    • 4
      Understand the F.O.I.L. method. F.O.I.L. is an acronym standing for first, outside, inside and last. It means that you multiply the first number of the first binomial by the first number of the second, then the numbers on the outside (the first term of the first binomial by the second term of the second binomial) and so on. This ensures that both numbers in the first binomial are multiplied by both numbers in the second.
    • 5
      Use the F.O.I.L. method to multiply the two binomials together. For example, (3x + 4)(3x - 4) = 9x^2 +12x - 12x - 16. Notice that -12x is the product of the outside terms and -16 is the product of the last terms, 4 and -4.
    • 6
      Simplify. There will almost always be like terms to combine. In the example, 12x and -12x cancel out, yielding the answer 9x^2 - 16.
    Dividing Binomials
    • 7
      Use the distributive property to divide both terms in the binomial by the monomial divisor. For example, (18x^3 + 9x^2) / 3x = (18x^3 / 3x) + (9x^2 / 3x).
    • 8
      Understand how to divide by a term. If you are dividing a higher order term by a lower order term, you subtract the exponent. For example, y^3/y = y^2. The number part of each term is handled like any other division problem. For example, 20z / 4 = 5z.
    • 9
      Divide each term in the binomial by the divisor; (18x^3 / 3x) + (9x^2 / 3x) = 6x^2 + 3x.
May 10, 2014 | Computers & Internet
How to solve foil method
The FOIL Method is a process used in algebra to multiply two binomials. The lesson on the Distributive Property, explained how to multiply a monomial or a single term such as 7 by a binomial such as (4 + 9x).
1.gif But, what if there was a binomial instead of a single term outside of the parentheses? That is, what if a binomial was being multiplied by another binomial? An example of this is given below.
FOIL stands for:
First - Multiply the first term in each set of parentheses Outer - Multiply the outer term in each set of parentheses Inner - Multiply the inner term in each set of parentheses Last - Multiply the last term in each set of parentheses Now let's give it a try in our problem. We'll start by multiplying the first term in each set of parentheses and then marking down the answer below the problem.
3.gif Now we will multiply the outer terms and again mark down the answer below the problem.
4.gif And the Inners.
5.gif And finally the last terms.
Jun 12, 2011 | Computers & Internet
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hi my Braun gives me the information, i have to replace the foil and cutter. So i buy a replce-kit, replace foil and cutter, but the messange still there. How can in reset the replace message?
You can reset it very easily..here is the method...
There is a small button under LCD screen..If you push that button 3 times a message comes as "foil +cutter" push 4.th times than you will have a message"reset foil" and push again and keep pushing until flashing stops it gives "Reset OK" message..it is done..
That's all..
regards
Mar 23, 2010 | Braun 360° Complete 8985 Electric Shaver
BRAUN 8595 screen indicates i should change my foil and block
there is a reset button directly underneath the LCD screen
Dec 02, 2008 | Braun Activator 8595 Electric Shaver
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
213 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
