Question about Cell Phones
When I press left top button on SE s700i to make a call the phone hangs and takes about 10 seconds to open the window to select who I wish to call. Also the Super Real tennis is very slow motion.
  • 3 Answers
Maybe you dont have a free memory on your phone.
Posted on Oct 01, 2009
How to reset an adr6350 phone
Preferred Method
  1. From a home screen, select the applications tab (located in the lower left).
  2. Select Settings.
  3. Select SD & phone storage.
  4. Select Factory data reset.
  5. Select Reset phone.
  6. Select Erase Everything.
  7. Perform Initial Activation/Setup.
Alternate Method
  1. Press the Power button for 3 - 5 seconds.
  2. Select Power off.
    linote.gif If the device isn't responding proceed with step 3.
  3. Remove/replace the battery.
  4. Press and hold the Volume down key then press and hold the Power button for 3 to 5 seconds.
  5. When the HBOOT screen appears, release the Volume down key and Power button.
  6. Press the Volume key to select FACTORY RESET then press the Power button.
    linote.gif This boot process takes several moments. If the device hangs or freezes, remove/replace the battery.
Mar 08, 2014 | HTC Incredible 2 II / ADR6350 ADR-6350 Hot...
How to set time.....paperwork not with watch
Button are bottom left A, top left B, top right C, bottom right d.
Mode button A, cycle through the various features of the watch.
Stop on the feature you wish to modify, press and hold B until the display flashes, repeated presses of B will toggle through the time/date options. Use C and D to increase or decrease the values. When done, either do not press anymore button (10 seconds display will return to default) or Press A to choose another mode.
Once you get the hang of it, you will be a configuration guru. I have a similar type watch. The function of the A,B,C,D may not be exact, but they function in the exact same way.
Good luck and don't forget to vote.
Oct 12, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
THE INSIDE SCREEN ON MY LG ENV3 IS BROKEN AND I NEED TO DELETE MY MESSAGES, HOW DO I DO IT? I NEED A WALK THROUGH
LG VX9200 w Broken internal screen
Clearing all txt messages (except locked)
with a closed phone from the external screen:
go to menu -> messaging
you should see{1. New txt
2. Inbox }
and so on
open phone
inside:
press right silver key below screen
press 4
press up
press ok
Please rate me.
Sep 28, 2010 | LG enV3 VX9200 Cell Phone
My current operating system is hang some time. How can I solv the problems or possible to re-install operating system?
Yea absolutely you can re-install/update firmware yourself but you need something to do.,.,.,.
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
rm303file And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose5310 rm436.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
Sep 27, 2010 | Nokia 5310 Cellular Phone
My mobile handset model is nokia 3110c.Its getting restarted frequently.I kept the mobile switched off and removed the battery too for some minutes.then switched on the mobile after a while without memory...
Secondly download
3110c files And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
Good luck.......
Sep 26, 2010 | Nokia 3110 Cellular Phone
Where is the self timer on the c-3000 digital camera
try to check this path: Press the Menu button, then press the top/bottom arrows on the Jog dial to select DRIVE. Press the right arrow and press the top/bottom arrows to select. Press the left arrow on the Jog dial to confirm the setting. If you take a
picture without pressing the OK button, the setting will be valid until the Menu is canceled. To take a picture using the selftimer, when the shutter is released, the Selftimer/Remote control signal lights for
approx. 10 seconds then blinks for approx. 2 seconds before the picture is taken. To stop the activated selftimer, press the Menu button.
Sep 06, 2010 | Olympus C-3000 Zoom Digital Camera
My iphone is hanged. i cannot turn off the iphone. i can see only the apple sign
To do an emergency restart of the iphone, press and hold down both the home button and the sleep/wake button at the same time.
If your iphone still hangs when starting and will not be recognized in iTunes then follow these steps:
Make sure the device is off before attempting this!
  1. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
  2. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  3. Run and open iTunes if it’s not already opened yet.
  4. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  5. You will be taken to the iPhone pane. Then, click on Restore.
  6. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
Jul 17, 2010 | Apple iPhone Smartphone
Ipod
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 23, 2007 | Apple iPod MA446LL/A MP3 Player
Video recording from my SE k750i
Sony Ericsson Phones have been known for those hanging issues, however, we have issues and we have resolutions. Have you ever upgraded the firmware on this phone? Even if the firmware is the latest one, I would suggest a firmware reflash. Don't forget to backup your data before you go for a upgrade or a reflash. In order to know the existing firmware on your phone, press this: > * < < * < * where < is left, > is right. Then go to the Software Info under Service Info. You may go to the official sony ericsson website; select you country; go to support; select the phone; download the Updater Service. And you would be able to find the latest firmware. Cheers
May 12, 2007 | Sony Ericsson K750
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
