Question about Lexmark X6150 All-In-One InkJet Printer
Alignment problem hardware error 0502. Printer is an X6150.Can n
  • hanem211 Nov 20, 2009
    my printex lexmark z2320, keep asking for a printing alignment test every time new cartridge has replace..is this a normal routine for all lexmark printer?. I find it unnecessary and wasting the ink.
    Do you have any suggestion on how to disable printing alignment test?
  • Lexmark Expert
  • 228 Answers
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please contact Lexmark tech support for further assistance.
Posted on Oct 01, 2009
    President:
  • 787 Answers
Try this:
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Showing hardware error 0504
To fix this hardware problem, please refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display.
Sep 19, 2011 | Lexmark X6150 All-In-One InkJet Printer
What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
Only prints to four lines of page. error 0502 comes up on screen. thanks
The 0502 error indicates either a problem with the encoder strip or a faulty black/color cartridge. Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine the cause of the problem and resolve the issue. If error continues even after following the steps, please contact Lexmark technical support for additional assistance. Thanks.
Jan 07, 2011 | Lexmark X6150 All-In-One InkJet Printer
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code raabe@shaw.ca
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Hardware error 0502?
Error 0502 can either be caused by a faulty cartridge or the encoder strip. Here's an article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. Just click on this link: http://bit.ly/b6uHJp. This should guide you on what to do when having this error. If error continues after following all the steps, don't hesitate to contact Lexmark technical support to further investigate the problem. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark X6170 All-In-One InkJet Printer
What is an error message 502?
The 0502 error can be caused by four different issues:
  • A contaminated encoder strip
  • An unseated encoder strip
  • A faulty black/photo cartridge
  • A faulty color cartridge
If the printer is still under warranty, it is best to replace it, as error 502 is usually recurrent. Otherwise, please follow the link below to the Lexmark website for a detailed troubleshooting guide for error 502:
I hope this helps.
Nov 19, 2009 | Lexmark X6150 All-In-One InkJet Printer
X6150 keep showing 0502 error when printing
I fixed my friends printer, Lexmark x6150 which had the same error and symptoms. The registration strip might be out of its so called slot but I doubt it.
Get several cotton balls and a bottle of rubbing alcohol. Turn off the printer. Soak a cotton ball, not dripping or saturated with the alcohol. Clean the paper path ( area underneath where the print cartridge carrier travels back and forth over the paper. ) This area becomes coated with ink and gets sticky, Clean the area until all ink is removed, you will use many cotton balls, continue until clean. Check the carrier parked area. You will note 2 rubber boots, 1 for each ink cartridge, make certain they are clean as well. They seal the cartridges so they don't dry out.
Jan 10, 2009 | Lexmark X6150 All-In-One InkJet Printer
LEXMARK PRINTER X6150 KEEPS GIVING ME A HARDWARE ORROR 0502
do you by any chance have the 1800 number that i can have. please
Dec 08, 2008 | Lexmark X6150 All-In-One InkJet Printer
My lexmark x6150 says hardware error 0502
Cause
The encoder strip may have gone out of range of the sensor, or it might be dirty.
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
    2. Disconnect the power cable from the back of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
      How to Perform the Hardware Test on the Lexmark X6150/X6170
Thank you
Nov 26, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
