Question about Nokia 3110 Cellular Phone
Phone was working, when the battery was very low, i switched it off to get the sim out of it and when I put back the battery to switch it on.. it doesnt want to start. Its been dead ever since, any chances of reviving the phone??
  • 97 Answers
Hi!... I think your battery is very drained. Try to "shock" the battery first. If you have a DC supply at home, set the supply at 6-10V then Put the negative terminal wire to the negative terminal of the battery and in a snap put the Positive wire to the Positive Terminal of the Battery. Then put your battery back to your phone and charge it. It will probably be ok.
Posted on Oct 01, 2009
My smart roaming sim lost its signal..i dont know why but still it has a remaining balance..what should i do??
You can powercycle your phone. Turn off phone,remove the sim card,memory card, and battery. Wait for at least 5 minutes then after 5minutes,you can put back the sim card,memory card at battery. Try to check if your roaming card will again work. If this doest work you need to contact smart telecommunications and ask them to deactivate then reactivate the roaming of your sim. Because if your sim wont work,there will be no access for you to retrieve the load of your sim.
Dec 02, 2011 | Cell Phones
My nokia 7610 got hang while browsing net.Then i switched-off the phone.But now it is not getting switched-on,when i press the power button the display becomes white for some time and then automatically...
may need servicing, but try to take out the memory card and the battery and SIM card. After that, press the power on switch for about 15 seconds. After that, try to put the battery back, make sure it is still charged, then turn on the phone again. If this works, you may turn it off again to place the memory card and sim card back and use your phone again.
Sep 08, 2011 | Nokia 7610
Deleting yahoo go from collecting software. Mobile immeatily switched off.3110c. Next time switched on only blinking immeadely getting switch off
try taking out the battery in mobile, then put it back in this might help.
(or)
Solution:-
1. Switch Off Phone (Remove Memory Car And SIM).
2. Star Phone Without Memory Card (But Now You Can Insert SIM)
3. Restore Your Phone (Factory Settings) Change Theme (Less Than 100KB In Size) Leave it Switch On For 10 Min.
4. Switch Off Phone And Leave it For 10 Min. (Remove SIM Card Also).
5. Insert Memory Card + SIM Card And Switch On Phone. 6. Enjoy.. :)
NOTE : -
1. Make Sure To Leave Free Space For Phone Memory Between 500KB +
2. This Will Effected For Next 4 - 5 Months … 3. If Phone Restarts, Then You Know What You Have To Do Now?
Sep 05, 2010 | Nokia 3110 Cellular Phone
How do you change a sim card in a motorola v3
Hello
If you want to change a sim, switch off the phone, remove the back cover, remove the battery gently remove the sim an place the new sim.
Put the battery again, cover the phone and switch it on.
Thanks.
Aug 11, 2010 | Motorola Mobility RAZR V3x Cellular Phone
My sony ericsion phone T230 shows SIM disloged problem. what is the solution for it?
Switch phone off, take battery out, then take SIM card out and replace firmly in the slot then put the battery back and switch on. Should be OK. This problem occurs because a shock to the phone has displaced the SIM card slightly and thus not making the proper contact.
Good luck
Aug 09, 2010 | Cell Phones
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
Phone doesn't switch on
This shouldn't normally cause a problem.
Make sure the cover is setaed correctly. It may have switch that checks the cover is back on.
Else take the battery out and put it back, ensuring correct poalrity. The battery contacts must line up with the pins on the other side..normally you can't put battery in the worng way. Let nme know the result.
Jan 11, 2009 | i-mate Smartflip Smartphone
My k610i just white screen
Try tehse steps
1. Switch off and switch it back on ,
2. Switch off and take out battery , when battery is out , press power on button for 30 secs and then out battery back again and switch on the mobile. This process is known as releasing flee power.
3. If still does not work, check whether the SIM is properly connected, take out SIM and put it back again and then check.
f still does not work then contact , the phone manufacturer, phone has to be reset or its not loading up properly and says inactive SIM , u can also contact the people whom u pay for the phone bills and check whether SIM is active or not
Feb 21, 2008 | Sony Ericsson K610i Cellular Phone
No LCD Display since battery low and phone switched off!
Try to remove the battery for 10 minutes and plug it back in if fully charged. Sometimes the battery just gets tired and needs a new replacement. Try to unplug it first like I said.
Oct 26, 2007 | Lands Phones
Nokia 3110 Cellular Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
